manta door hinge pin removal
Okay, I have the typical sagging driver's door on my 73 Manta. Being smart, so I thought, I purchased thru JC Whitney their door hinge pin removal tool. Great tool except for one thing: it only removes "solid" hinge pins, not the "hollow" ones that Opel uses on the Manta. I have tried soaking the pins with various lubricants (PB Blaster, WD40, etc) and then tried to drive them out with a solid rod the same size as the hinge opening itself: no luck.
So I have 2 questions: 1) what have the rest of you done to replace the hinge pins (I have new ones from OGTS)? 2) has anyone tried driving a solid pin thru the middle of the old hollow pin to "beef" it up? This idea seems plausible as the solid pin would stretch the hollow pin back into shape and restoring the normal action of the hinge. What do ya'll think?
