I recently was presented with the challenge of adding a disc-brake rear axle to friend's Ascona. The straighforward installation of the axle is simple, the problem that ensues when using rear disc brakes on a car not designed for it is the front-to-rear brake bias. Most master cylinders for front disc/rear drum applications are biased at approximately 65% front and 35% rear, because of the volume of fluid required to activate the large pistons in the front calipers compared to the smaller pistons in the rear cylinders.
Adding rear disc brakes requires a larger volume of brake fluid to be sent to the new, larger caliper pistons. Not doing so will make the pedal 'lower' than usual, as the normal fluid volume that is sent to the rear cylinders only partially applies the clamping force to the new rear caliper pistons. Numerous pumps are necessary to get a firm brake pedal. Adding a brake proportioning valve is not the answer....they only reduce the amount of brake fluid, not increase it. So the answer is to install a master cylinder with a greater rear bias. Not a problem if your car was available with an optional rear disc setup, just order it from the dealer, right? Yea, sure, we're talking Opels here folks!
For the Opel Manta, I haven't found anything that is a direct bolt-up for rear disc brakes. And to be honest, the brake booster in my friend's car was starting to stick anyway. So instead of replacing the master cylinder (usually about $150-$175 for a stock replacement anyway), and rebuilding the booster
($100 to $150), I said 'screw it' and built a custom adjustable brake pedal assembly for his car, eliminating the brake booster altogether. The trick was to make a custom pedal asembly but retain the stock clutch pedal arm....but there's not a whole lot of room under there to do this. So I just modified a stock Opel Manta/Ascona pedal cluster, retaining the stock clutch arm location and adding the adjustable balance bar pedal assembly and twin racing master cylinders. Total cost was just over $200 for the twin master cylinders (7/8" front and 3/4" rear), and the pedal assembly from Wilwood. I went with the 12" pedal length to increase the leverage ratio so the pedal effort wouldn't be too difficult.
For comparison, here's the stock pedal assembly:
