Cad model and cast the stock injector mounting plates, but make the spot where the injectors go wider so it can be drilled stock or custom...
60 mm bolt spacing center to center both horizontal and vertical. And a 60 mm throttle throat diameter. Don’t remember the original bolt size, but I drilled mine out and tapped for M8 x 1.25 mm pitch bolts.What's the bolt spacing for the throttle body?
Cool, that’s what I was hoping for when I started this project. Do you happen to have a VW throttle body handy to check the bolt pattern and throat diameter?Mk3 VW either 2.0 4cyl or 2.8 VR6(bigger) throttle bodies are cable operated Bosch units with tps and stepper idle control.
I bought one maybe 10 years ago, and needed it for a project 2 years back. Couldn’t find it, so I bought another.I really wanted to order the special drill that drills all of the fuel rails holes at the same time. But, it was just too expensive (close to $100) for a one time use. Although, that is what I would recommend if you are making your own fuel rail. So, instead, I ordered a 14mm drill bit.
I set the depth on my drill press to 10 mm.
and drilled all of the holes to 14 mm.
Then I cleaned up the inlet edge with a 5/8 drill bit and some fine grit sandpaper.
I am still not happy with the wall finish. So I am 3D printing a quick (20 min) 14 mm mandrel to hold some fine grit sandpaper to smooth and polish things up a bit.
That's the way it always happens no matter how well organized you are or think you are stuff just has away of hiding from you. Even when your staring right at it LOLI bought one maybe 10 years ago, and needed it for a project 2 years back. Couldn’t find it, so I bought another.
Of course a year later I found my original….😳
Wish I had that. Hopefully mine turned out alright. I will only know when I pressurize it.I bought one maybe 10 years ago, and needed it for a project 2 years back. Couldn’t find it, so I bought another.
