I looked at 6 of the 7 engines that I have. Out of the 7, 3 are High Compression. Flat top pistons. The first one was a 1 owner known 70 model engine, Block nos. *19S-0473836* , the other one is Block nos. *19S-0812336* , that came with the 69 I have. What does that mean if they quit with block nos. 19s-04xxxxx? It doesn't appear to be rebuilt, I have no way of knowing. The third was in my original Manta, rebuilt as per the C&D article. Didn't get the block nos., as it didn't count. One other (69), was covered up with a tarp and I didn't want to go to the hassle of pulling it off as it is still covered with ice. The only common denominator I could see was the blocks that had the *s, before and after the block nos., had flat top pistons with notches for the valves. I did not pull the valve covers off the above two to see if they had solid lifters. I'll pull the valve cover off the 70 block tomorrow and check to see if it has solid, or hydraulic lifters. Jarrell
