1 - 15 of 15 Posts
My question, which way do they point? Depending on which side you put them on they either locate the engine a little forward of the mounting location on the chassis, or behind it.
The reason I am asking is I am installing an aluminum radiator in a 1900 and there is no room between it and the engine for the pulley and fan. If I swap the mounts I can move the engine back a bit, maybe 2 inches, which would do the job, but then the shifter moves back and also the transmission mount.
Tire Automotive tire Wheel Motor vehicle Tread
Automotive tire Bumper Tread Rim Automotive exterior
Motor vehicle Gas Automotive exterior Machine Auto part
· Super Moderator
Engine forward is original and correct.
Reactions: guyopel and m610
· Administrator
I ran into the same issue with the Manta I'm working on. I ended up using 2, 7-inch fans.
If you use 2 t-stats, you can set it so only one comes on at temp and set the other
Motor vehicle Automotive tire Hood Gas Vehicle
a little higher.
If you use 2 t-stats, you can set it so only one comes on at temp and set the other a little higher.
Thanks. I think that's what we'll end up doing. Do you happen to remember where you got your fans, and model?
· Super Moderator
A little bit late, but here’s some pics of the engine mount orientation.
Note that, in addition to being swept rearward, the mounts are different lengths. If you reverse the mounts, the engine sits crooked under the hood, and misaligns the driveline.
White Light Black Automotive engine gasket Audio equipment
Gas Automotive exterior Auto part Bumper Fashion accessory
Reactions: m610
· Super Moderator
The ones Gary has look similar to the ones I bought from Speedway Motors for my Sportwagon.
Electric fan Gas Camera lens Machine Camera accessory
I made a foam buck (for a mold) in order to make a fiberglass fan shroud.
Keep in mind this is on an aftermarket Scirocco aluminum radiator which is placed a little bit forward in the chassis.
Tire Automotive tire Hood Table Automotive design
Purple Creative arts Rectangle Material property Wood
Amazon. I had the relay and t-stat.
Gary, it looks like I'll order the same and have it shipped to Mike. As far as the 2 thermostats to control the fans separately, I never heard of that or know how to set that up. It might be useful here in AZ, especially since the car has AC. When we go to a show in (Mark Paar's) the Manta we don't use the fan or the AC at 7am but need it when coming home. Is it Difficult? I assume just a pair of on/off switches for the fans is what most people go with. Thanks
· Administrator
Here is the one. I used two in my wagon. One is set for 190* and the other at 200* (it only comes on if the first one can't cool enough)
Product Bag Luggage and bags Font Output device
Discussion Starter · #14 ·
I use the type of thermostat that screws into a bung in the radiator. It has a fixed temperature setting, but that's fine with me.
Also, the first thermostat failed before long. I replaced it, and now I also have a switch I can use to override the thermostat.
For Craig's car, I'm thinking of using the thermostat for one fan, set for the higher temperature range, and having the other fan always on.
Mike
· Master Story Teller & Fabricator
One company in China makes all of those plastic fans, regardless of the name on them. The giveaway is that all of the motors have that "12V 80W" sticker on them and they use the same size motor on all the different size fans. There is a different shape to the fans, though. Over the past few years they have evolved the fan blades from straight, unconnected at the tips, ones to very curved ones that have an outer ring that bonds all the blades together. The latter is highly recommended, the unconnected blade types can have the blades snap off if they hit anything and the highly curved blades grab air more efficiently. There are literally 1000's of them for sale on Ebay. The small 7" fans don't seem to need the outer connecting ring on the fan blades, but the larger fans with curved blades do have the ring.
1 - 15 of 15 Posts
