1 - 3 of 3 Posts
motor problem
i recently bougt a opel gtj from 1974 whith original 1.9 motor and solex carburator.
now i`m trying to tune the engine and i have a problem.
the motor is running bad in some cases.
this is when i drive at low speed (30mph) in the third gear and i accellerate, the engine starts to give a strange noise. it sounds like there is something ratteling in the engine. now when i consist in accelerating and the engine comes at higer RPM (above 3500) the ratteling sound almost stops.
when i start to drive and i accelerate normal/very slow, the sound is not present.
but if i accelerate quite fast, the rattling sound is heard in all gears.
had anyone an idea what might be the cause of this??
sounds like your timing is out and it is causing pinking(per ignition of fuel)
check static timing first then check fuel mixture
It could also be the timing chain tensioner. This part is known to get weak over time causing the timing chain to rattle upon sudden acceleration or deceleration. Do a search on this site for solutions (some cheap and some not) for timing chain / tensioner / noise / rattle and you should get your answer.
1 - 3 of 3 Posts
