I thought I'd start a new thread on this project since the previous thread "Modern 2.5 - 2.7L Engine Build" was more information and idea gathering.
So I started with a 2.4L core engine from Charles and after much research and searching for parts this was the final recipe:
Lower End:
Top End:
I'll post some pictures of the final assembly along the way. Plan is to use my Sniper EFI setup on the engine and header with 2.5" exhaust.
Lower End:
- VW G60 H-beam racing rods: 136 mm length
- KB 1745HC-5mm pistons: 97 mm bore. Pistons are dished for 5mm but was enlarged in diameter and depth to increase to about 11 cc. This was done on a lathe. Dishes are 0.08 deep.
- stock 2.4L crank was offset ground to 48 mm journal size to match the VW rods and shoulders widened only a fraction of a mm to fit the rods. This allowed a 3mm increase in stroke and was super easy according to the machine shop.
- crank was balanced, etc. by the machine shop (Ohio Crankshaft) and block assembled, all clearances checked. There was no interference anywhere including the piston skirts or block. This machine chop builds racing engines and the manager (Jeff) was unbelievably helpful and answered a million questions from me.
Top End:
- Stock 2.4 Head cleaned, inspected, etc.
- 1.88" ss intake valves
- 1.60" ss exhaust valves
- all new guides, seals, seats, springs, cups, retainers using SBC parts according to the shop manager. Seat pressure is 100 lbs and open pressure is 210 lbs. These specs came from recommendation from Bob and others. I really had no idea how to design this area but Jeff said this was no issue for them and was quite easy. It's good to have a good machine shop.
- Cometic .040 MLS head gasket (still on the way)
