I finally got to really look at the GT this weekend as lots of personal stuff kept cropping-up. Still don't have a digital camera, and my computer @ the house carked. So I can't provide photos.
The engine is around 2.2l with aluminum domed pistons, floating shot-peened rods, and a stroked crank. Compression about 11:1
Head has a "quickie" porting job by Mr. Legere. Also has doubled springs with a 3rd spring-like thing which rides in the middle of the two outer.
Got an Isky Combo Cam since my others: had a lobe that went missing, or produced compression too high for pump gas.
I had to recurve the distributor as pinging was bad, not as bad as with the stock cam I have, but still bad. So, I put 2 heavy springs in the distributor, and added shims around the spring post to limit total advance. The problem was that to eliminate detonation I had to substantially limit total advance. The result was an engine that was very lethargic.
Tell me if this makes any sense, and why it seems to have helped, as I haven't a clue. I unset my vacuum advance which was @ 0°, to total retard. Then, I added some total mechanical advance.
On brand name 93 Octane, AND "Off-Road Use" Octane Boost (+2 octane), I can control detonation. However, if "off brand" gasoline or "street legal" octane boost are used- detonation will occur, it will ping @ startup, and/or it will get a horrible case of run-on.
If you think it will cure my problem, I have one of those thick Risse 2.0l head gaskets to lower compression. I am leery to use it, as it is the last head gasket I have, head gaskets were hard to find last time I checked with OGTS, and I don't want to put it on just to find out it didn't work as well as expected and solving naught.
I could buy another solid cam, but solid lifters are becoming uncommon lately.
