Hi Guys.
I have tried to start my gt after the winter, with no luck.
My setup is. 2.0 cih with Weber’s and electronic ignition from 2.0i with a flamethrower coil.
As for a start, it was running great before the winter. So, first off I thought it was the battery so I changed that.
It does get fuel as the acceleration nozzle does spit fuel.
But my ignition seems strange..! First off I did not get any spark so I changed the coil to the old one I had. And took the direct 12v wire off. Now I have spark but it seems like it is firing at all kinds of times. When I turn it over it seems like it’s firing before the tdc, as it “stops turning” or have a hard turn when it fires. Still no sign of starting.
I now though I had problems with my distributor so I changed it together with the ignition module. And it is still the same now.. no change.. I then heard like a clicking noice when turning with no plugs, a clicking that had same strange timing as my spark. So I tried to touch things while turning the engine, I got a shock from my distributor so there must be something wrong still there..
But I already changed, distributor, coil, ignition module - what else could be wrong? Do you guys have any suggestions?
Best regards from the Danish GT owner that just wants to have his first ride in the Easter sun.
