1 - 4 of 4 Posts
my injector problem
Hi; i have ASTRA GSI (97) 20 16V ( 20 XEV)
my engine doesent star at the first fire....
we checked everything and found the problem
i need the 20 XEV's injector number , or type
i have to change the injectors because they spout too much fuel.
thnx yaðmur
Ps: i've asking this info because my frined who is in USA will send 4 injectors for me and he's asking this type of injector or number..
Administrator
Hi yaðmur,
Maybe one of our European members will answer your question. Most of the people here (U.S.) have not seen an Opel newer than a 1975.
Would an Opel Parts dealer in Germany or Turkey be able to give you the part number? Have you checked to see if a relay is stuck causing the injectors to spout too much fuel?(Just guessing)
Good luck,
Gary
injectors
hi yagmur have you checked the temp sensor for the injection computer it may be failing and letting the comp think the car is cold and then running the cold start enrichment ( adds more fuel like a choke ) a calibra i had used to do the same
i hve changed the cold start sensor ignition, cables
Could the injectors have toruble or u say the injectors have two chanses like: 1-it perfectly works 2-goes off and pumps less fuel
but i have a trouble like i cant start the engine because of more fuel.... the car goes stupid
and my friend will send me a like injector for my car not the same...
1 - 4 of 4 Posts
