I just threw this together tonight. NOT Professional by ANY means, but it is something that I can use to track the progress of my car.
http://www.ttwatchworks.com/opel.htm
How about 10:00am. That way it is still a little cool and we have a built in break time at lunch.Thom71GT said:What time do you want to start?!?!?
If you need a pickle fork, you can rent them from Autozone for free (full refund on the rented tool when you return it). That's what I did when I rebuilt the front suspension on my GT several years ago. It really saved the day. Same thing for brake pipe benders and several other tools that you typically don't need on a regular basis. Last time I used their service was for a ford clutch fan wrench.Thom71GT said:Oh Oh, yes. Do you have a Ball joint fork thingy. (I think thats the offical name of it). when you lower the front, it puts a negative camber on it and you have to rotate the ball joints 180 degrees to correct it. I dont know if you have to take them out or not. Ill call OGTS and find out.
bq97 said:I was in the process of replacing my ball joints so I thought I'd take a few pictures of the upper ball joint to share with those that have never had their front end apart.
The first picture shows the upper ball joint before it is attached to the upper control arm, notice the offset in the mounting holes.
The second picture shows the ball joint in the standard position and the third shows it rotated 180 degrees.
hth
Brian
tom_laan said:nice page you made. it doesn;t look bad, and if you can do that, you can do even more, do you know xara webstyle? thats a program to make a website that looks professional but can be made with basic html skills.. i made some and planning to make one about my gt too. and gt in general. but it can be downloaded off the web.. if you are furmiliar with that. if you want to know more about it pm me.
cheers
tom
