1 - 20 of 30 Posts
Can Opeler
That bolt has not been present on any GT I’ve taken apart. So I’m assuming it goes to a very often replaced part. Maybe it’s the alternator upper mount?
I know the GM AC unit had tons of extra bolts too maybe something from there?
That’s a strange bolt though. Almost looks like it’s designed to let fluid pass around it and rotate. Could be hidden inside something I missed though.
Opel Key Master
Discussion Starter #13
That's a vague question, so I will not answer unless you mention a specific bolt. The reason is even if you said is it a headliner bolt, I would want the guess to be specific to what the bolt in the headliner did or was at. I'm liking this one...I thought it would be a tough one...since even I had some of the bolts and never knew or could figure where they went to.
Can Opeler
How about a bolt near the spider gears in the rear axle?
I don’t know what they are called but there are four bolts if memory serves.
1 - 20 of 30 Posts
