Most Bosch Blue coils don't need a ballast resistor, because they have one integrated in their housing (there are some rare "Made in Mexico" and "unknown origin" that don't, which should be avoided cause they are crap anyway; everything "Made in Germany/Spain/Brazil" will have a resistor).
This is my set-up for the past 5 years. I replaced the resistor cable for a regular one going directly to the "15" terminal of the blue coil. Has worked beautifully, and never had breaker-points getting fried...
You can verify that your coil (and any coil) has integrated ballast resistor by measuring resistance between the "1" and "15" terminals. Below 1 Ohm, no resistor, above 3 Ohms there is one...
So, if you have the second case, with integrated resistor, you shouldn't worry, you are running a correct circuit...
Hope this helps
P.S. My old blue coil was made in spain and had a plastic cover, and used to get hot. A new one I just purchased (made in Brazil) has a beautifull polished metal cover (Bosch 0 221 119 027) that looks nice, and keeps it cooler!!! good iffo about bosch blue coils at:
http://www.ratwell.com/technical/BlueCoil.html
