New production single side draft intakes from Basti Marz
1297 Views 37 Replies 9 Participants Last post by  mark1
4
The guy that makes Risse's single side drafts intakes and will be making my GoinEFI intakes has his own single side draft design for the GT.
Designed for a 45DCOE and specifically for the Opel GT ( Its even tilted )
Also Flows better than the MIDIKit (not tilted) or Steinmetz and as we know that aint hard - Custom 3-D Printed Intake Manifolds? )
Motor vehicle Automotive tire Automotive design Hood Automotive lighting
$250 and shipping from Virginia if you want to wait on my crate ( ETA Sept? )
You pay him the $250 ( or 199e and shipping from Germany )
If you are going to have it come in my crate you pay him the $250 and me the $20 to ship to you when it gets here.
Any questions and /or to pay contact Sebastian März - sebastian.maerz<a>outlook.com
See less See more
  • Love
Reactions: 4
1 - 20 of 38 Posts
Where is the brake booster outlet? Drill it or them yourself?
It is drilled by Basti. Just cant see in the pictures above and you use one of the runners, as there is no common plenum.
See less See more
That looks awesome! If I ever put a side draft on a opel I will keep this in mind.
I’m definitely interested in testing one. Does he have any flow data to prove it flows better than the midikit? I’m highly skeptical of all single side draft manifold designs. The midikit manifold is tilted correctly for a GT too.
When is your next shipment coming in? I’ll grab one regardless.
Correctly tilted midikit manifold to adjust for opel GT engine lean.
Sent from my iPhone using Tapatalk Pro
See less See more
Would also need a balance tube between runners for idle quality. If it doesn't have one the carb flange is thick enough to drill.
NO idea.. thats why I put the email in the post to contact him.
Same for paying him, etc.. this was all the information I have.
I was not aware the MIDIKit manifold was tilted correctly I thought it was generic for the CIH..
Shipment should be at my house early Sept ( or earlier I hope ) So many pieces have to go together. But it would be best for me due to my bond expiring in Mid August for it to be here before then, otherwise its another $600+ for a bond...
On my Steinmetz I drilled a 10mm passageway through the side of the carb mounting flange to help unify the vacuum, then plugged the hole. The brass square is the pipe plug in this pic.:
See less See more
I’m definitely interested in testing one. Does he have any flow data to prove it flows better than the midikit? I’m highly skeptical of all single side draft manifold designs. The midikit manifold is tilted correctly for a GT too. When is your next shipment coming in? I’ll grab one regardless.
No, but I am working on a Diagramm between Midikit and my Manifold
  • Love
Reactions: 3
Nice to hear from you. I'll be one of the first to get one of your fuel injection manifolds that Charlie designed with help from me and others. I'm looking forward to setting up and using your product. Thank you for helping us out on that project.
Any chance that you could design an 1 x Weber IDF intake for the 1,0 - 1,2 ohv ?:)
Welcome to the Forum Basti ;)
BTW.. if you think FB can be unforgiving.. ;)
Reactions: 1
Yes, thats possible, but I think there is just a small market
Reactions: 1
With my Manifold on 2.0 CIH
See less See more
  • Love
Reactions: 2
See less See more
  • Love
Reactions: 3
I would be interested for sure if you do.
Count me in too. My 1.0L would love an IDF.
You’d also make a ton of sales in this group:
Do you have a Picture of the Part you need?
2
It’s for the Opel OHV 1.0-1.2 used on various Kadetts, GTs, etc
See less See more
1 - 20 of 38 Posts
