I am working to build a very nice street suspension setup on my 72 GT. I don't want to go too stiff as I am not planning to race it. I want a suspension that is nice to ride in yet handles well. It must be lowered as I really like the look of a lowered GT.
I am considering the following:
1. OGTS intermediate spring (the one that doesn't lower it very much) and then add lowering shackles to put the front end 2 inchs down. The shackle will allow the front suspension to move without binding.
2. Cut down the stock rear spring to match.
3. Put on Addco swaybars. These are softer then the OGTS ones so will allow some body sway. I found the OGTS sway bars to be pretty harsh for a street car when I had them before.
4. Lower the rear pan hard rod some and make sure the bar as level and the correct length.
5. Either use Koni Red shocks or the Rancho 9000 adjustables. I would like input on anyone who can tell me how the Konis and the Ranchos will compare. I like how easy the Ranchos can be adjusted. If Bob L. sees this which Rancho's would you use in this application or would you use the Konis?
6. I will put heim joints on the tie rod ends and then drill the hubs. Then mount the joints on the other side to correct bump steer.
7. I want to add an upper shock tower cross brace.
8. I will also put in probably soft poly bushings.
9. The wheels will either be 15 x7s or 15 x8s. If they will fit ok I will use 215 50 15s
What do you guys think? Remember I am looking for a firm OEM kind of ride.
Thanks for you input in advance.
Derek Greenwood
72 GT
Derek Greenwood
72 GT
