Hi there.
I've been lurking this forum for a while, mainly trying to colect knowledge about the engine on my 1968 1900S Rekord sedan, since it is the same used on GTs.
Anyway, since there are so much similarities, the forum and your threads have been really helpful.
Up till know i've always doubted that my secondary was working, mainly because in 4th gear the car would only reach about 130kmh with great dificulty, and in lower gears it did not seem so "alive" as one could expect for a 1900cc, altough many reasons for this could be pointed out.
Also, accelerating "by hand" on the carb linkage, I could not make the secondary work, unless I opened it also by hand - and in those moments, man did the engine become posessed!
On a recent search I found this thread: http://www.opelgt.com/forums/linkage/16004-throttle-grommet.html.
I've got the same problem and IMO this could explain why the secondary does not work: by throttle pedal is really loose, loose beyond what one could consider normal. Checking the firewall on the engine compartment, I noticed that the first rod on the linkage is very, very loose and surely some bushing is missing.
Could anyone post a closeup pic of this part of the firewall so I can see what could be missing?
Thanks a lot and sorry for posting while not being a GT owner.
Cheers from Portugal!
