ok --this is what i think im gona do.need input/advice ect.
a friends son totaled his bmw 1982 320 i with245/5 getrag.
he made a gift of trans including flywheel back.
lets put that sucker in da opel!
this is only worth doing because trans is free and all machine/weld/ect can be done "in house"
the ratios look beter than the opel getrag.
bmw--3.68/2.00/1.33/1.00/.81
opel5-3.77/2.019/1.316/1,00/.804
opel4-3.64/2.12/1.336/1.00
this ratio info might be wrong but best i could find.
things i think will work
1 cut bell housing off bmw trans and machine front of trans flat--bolt or weld opel bellhousing to trans--may need spacer.front trans case will chuck up in my brake drum lath
2 instal hard sleve on bmw input shaft to use opel pilot bearing.
3machine and drill opel flywheel for bmw clutch and pp.
4 if spacer is used(beel to trans) i think i can stay with opel throw out brn--if not will have to adapt bmw throw out brn.
5 shifter mod--no problem.
6speedo--will solve later
7the PROBLEM--out put of bmw is flanged with no provisions for plunge(sliding splines)the opel has some plung at pinion end of drive shaft--this might do it but is probably a no no. have not pulled flange off yet to see if its removel will cause a thrust problem on output of trans.if it doesnot and splines are deep enough i think i can make it work
or possibly use a cvc joint at the back of trans ?(bolted to flang)
#7 is my biggest problem at the moment--any ideas?rallybob?
8 need dissasembly info on trans
Thanks
David
Thanks
David
