SUCCESS! I've removed my first head. It was a blast. It took about 5 hours total with running to the hardware store a couple of times. My 2.4 doesn't have the 12mm serrated bolts. It uses 10mm hex bolts. And upon consulting with Roger Wilson on the best way to rotate the engine to #4 TDC, I got a "breaker bar" and a 19mm socket. I actually didn't use either to turn the engine. I just used a crescent wrench because that was the best tool to get between the fan and the crank pulley.
And why get all technical about #4 TDC? Why not just tell a first-timer to line up the recesses on the camshaft with the head bolts??? It sounded so intimidating.
Just kidding. I appreciate all the advice I've received here.
One "OOPS" in this process. I dropped one of the 3 8mm cam gear bolts. I can't see it from the top. Is it in the oil pan now? And if so, any caveats as to oil pan removal?
Thanks again to everyone,
Manny
Manny
