I have two pickups, one from a 2.2 which is backwards because the sump is in the front, and one from a 1.9 with a steel pan. I have not checked to see where the problem will be to make one of them work. Seems to me if it's steel, I can fix it. Heat, hammer, welder, tube bender, material availability, I have it all, how hard can it be. It sure would be nice to know what the difference is between the steel pan and aluminum pan pickups tho. I measured the pans last night. The ali pan has a 5" flat spot on the bottom before it rises 3 1/4" and the steel pan has a 6" flat spot before it rises the same, but at a more shallow angle than the ali pan. My guess is this is where the problem will be. The ali pan is also about 1/4" less in overall depth, but I doubt that the pickup will hit the bottom, I can't imagine that the pickup sits directly on the bottom of the steel pan. Such a simple thing, it will probably take me a whole day to work it out.
