Ok, I give up.......how do i get the oil pan off? Bolts are out, nothing seems to be hindering it except the silicone I see that squirted out when the last person replaced the pan. I didn't want to do too much prying before I found out if someone has a trick way of doing it.
ALSO......after I took out the engine I found this laying on the floor and I'm not sure where it came from.....it measures approx 30 mm X 45 mm with a 12 mm hole in the middle and is 2 mm thick. Some sort of spacer I assume but not sure.
Any help on these two items appreciated.
