i have took a non running 1.1L egine apart awhile back and noticed the oil pump was inside the engine.. is this the same way on the 1.9? my car reads 2.5 bars when i first start it up.. but then after a bit when it warms up it goes down to one bar at idle.. but if i go down the road it will go up to two bars.. then when i have to stop the idiot light comes on the pressure is so low.. but then it goes back up to one bar.. so is the gears and cover on the outside the engine? and if so if there more to it then taking off the old one.. and putting the new one on? and will this fix my problem?
P.S.. got all other kinks worked out.. and its running great!! and should i drive it like this, with oil pressure low???
