Final exterior
Here are photos of the final exterior
Great color!! and nice rims!Old Yeller got its first bath yesterday and front end alignment
Thanks.Great color!! and nice rims!
Just received the December issue of Hemmings' Sports and exotic car magazine. Old Yeller is on page 53.
Do you have to change the coil? Is it powered with the lower 9 volt source, after the car starts, or do you have to change that to 12 volt?The PertronixI III is the easiest to install and has the added feature of providing multi-spark and spark amplification, plus, rev limiting(unneeded on our cars). That's what a giant MSD box does! And you get it all in a gizmo the size of a AAA battery. Never mess it or points ever again and your engine will burn fuel more efficiently. Highly recommended.
No matter which electronic ignition you select (and FWIW, I personally prefer the Pertronix II, #91847), the ignitor device should be powered with a full (un-resistored) 13.5 volts (just being precise since 12 volts isn't actually accurate). Easy to install a 14 AWG wire from the switched side of the fuse box to the ignitor.Do you have to change the coil? Is it powered with the lower 9 volt source, after the car starts, or do you have to change that to 12 volt?
Great information. Thanks for the help. I read somewhere that there is no advantage on upgrading to a high output coil? Also, should the 13.5 volt wire be fused? Your thoughts on these two questions?No matter which electronic ignition you select (and FWIW, I personally prefer the Pertronix II, #91847), the ignitor device should be powered with a full (un-resistored) 13.5 volts (just being precise since 12 volts isn't actually accurate). Easy to install a 14 AWG wire from the switched side of the fuse box to the ignitor.
As for the coil, the power source for it and the need to change or not change the coil depends on a couple of factors.
If you use the Pertronix I (#1847), then an OEM (low resistance) coil has to be powered by the stock resistor wire. If the coil is a 3 ohm device (such as the Pertronix Flamethrower matched to the Pertronix I), then the resistor wire should be bypassed.
The Pertronix II and III can (and should) use the stock low resistance coil without the resistor supply wire. Same for a higher performance coil.
And why do I prefer the Pertronix II? Far more durable than the Pertronix I (won't fry if left turned on), auto-dwell adjustment, and cheaper than the III.
A high output coil is only an advantage if higher spark voltage is required. A low compression, low horsepower; small'ish carb (eg Slowex)) is unlikely to gain any horsepower or driveability from a high output coil. The opposite is, of course, true.Great information. Thanks for the help. I read somewhere that there is no advantage on upgrading to a high output coil? Also, should the 13.5 volt wire be fused? Your thoughts on these two questions?
