I would question the use of a draw-through turbo with carburetor on a used Opel engine. I've tried it before, but the standard Opel intake manifold does not have great air/fuel distribution, even with a carburetor bolted to the intake. Increasing the distance by placing a turbo between the carb and intake makes this worse. I'm not saying it won't work, it will, but you're about at your limit boost-wise. You can't add an intercooler on a carb'd setup either, and the stock low compression pistons are notoriously weak at the ring-land area. I'd be surprised to see much more than 30-40 percent increase in power, which means that a smog-era Opel (gross) 1.9 would go from 75 hp (gross) to about 100-105 hp. Also, sustained high speed driving will DEFINITELY require an upgraded cooling system, turbos create unbelievable heat.....enough heat to catch anti-freeze on fire, and that stuff does not burn easily!
I suspect that unless you start with a new rebuilt engine (new pistons definitely) and very careful setup (impeccable tuning of the air/fuel mixture and re-curving the distributor, plus and GOOD electronic ignition, there will be reliability problems and potential engine failure. In this day and age, the only way to go with a turbo is a stand-alone programmable fuel injection system.
RallyBob
