1 - 7 of 7 Posts
opel gt preformance parts
i am intrested in to upgrading my opel gt and dont want to do toomuch work what can you sugest to do. or if there are any esay engion swaps what would you sugest. please help :confused:
crazy opeler
To use the rotary engine you would need to make these modifications.
1. Custom engine mount and trans mount, this is fairly easily fabricated.
2. I would suggest a custom radiator with electric fan.
3. you would need to have the output shaft of the trans made to the propper length.
4. Custom throttle setup, I suggest a cable setup as uposed to the lever system that is stock on the GT.
5. there might be a slight modification needed to the driver side foot well area, but nothing major, the rotary is a small engine.
6. A custom exhaust would need to be fabricated.
7. Front spring shackels. The rotary motor weighs less so you need to lower the front end.
Actually most of these things would need to be done in any motor swap, the rotary would be my choice because of it's small size and weight. It would require minimal modification to the engine compartment.
Detritus Maximus
Rotaries put out a LOT of heat and noise, so some decent heat shielding and good quality exhaust parts.
Currently in Opel Detox.
In the experience of the engine swappers, has anyone ever moved the master cylinder back to the firewall (box) area and increased the width of the radiator and put it on a slant design like the mid-late 80's rx7's.
-bret
Administrator
-bret
There was a guy in MA who mounted an aluminum radiator at an angle just behind the grille. It really opened up the engine compartment and he mounted some F.I. components where the original radiator was. Here's a pic:
1 - 7 of 7 Posts
