First of all, hello to all of you. I was following the forum but I was not a member. Super information is shared. So thank you all..
Now as for the problem I'm having.
I was using varejet carburetors before. Then I got solex addhe 40 carburetors. However, after installing these parts,
Problems
1-I did not see a big difference in terms of performance. Except for the sound
2-4000-5000rpm problems,
3-Exhaust 3000 -4000rpm exploid blupp blupp.(carb no spit)idle performance its ok.
Possibilities
1-fuel jets (Is there a measure I should use?) as if the car is running rich and float problems..
2-injection problems (use old series bosch blue coil 3ohm)
3-Use stock mechanical fuel pump.
4-vacuum problems.
Is there any other possibility you can suggest?
Problems
Possibilities
4-vacuum problems.
