Solid State
The "Otto Start" shifts the electrical load from the delicate Opel ignition switch to a remote set of points in a relay. This protects the irreplacable ignition switch contacts but still does not fix the continuous running of the starter when the points in the "Otto Start" relay weld themselves shut instead!
The "fix" that has been explained to me is to replace the "Otto Start" relay with a solid state relay that, if it fails at all, fails to open circuit so that the starter soleniod is not continuously energized.
The "Old" technology of the "Otto Start" just needs to be updated with a modern solid state relay to protect the delicate ignition switch AND prevent the starter solenoid being continuously operated should the protective relay fail - as the original Otto ones are prone to do (as you found out).
