I'm at my wit's end with this one and hoping somebody has a clue what might be going on here...
Symptoms:
Alternator is overcharging battery at 17+ volts. This is confirmed by my digital voltmeter at the battery and at the alternator b+ terminal. Also, my dash ammeter pegs to 30+ when I rev the engine up.
The problem CANNOT be the voltage regulator, however. I've tried several confirmed good ones and even tried a brand new one with no change. I have also replaced ALL wiring to/from the alternator and voltage regulator and have verified proper gounding of the regulator. I have checked/replaced all my grounds (frame to block and alt to block), and I have cleaned and verified battery terminal connections and fuseblock connections.
Is it possible that there is something wonky inside the alternator itself? Or, that my dash ammeter has shorted somehow to cause this condition?
The car is a 1.1L GT.
Symptoms:
