1 - 11 of 11 Posts
RunOpel
They are awesome, one of the first things I did when I got my GT :)
Discussion Starter #3
There isn't anything wrong with my current radiator. But I was afraid they would be out of stock this winter when I install my 2.2.
I'm glad they came in. I came very close to buying a Honda 3 row last week.
RunOpel
Oh you will be glad that you got one of those radiators from OGTS. When I got my GT the radiator was the original and didn't appear to have any issues, but I just wanted to upgrade all the old parts with new.
been waiting almost if not a year for these to come back wooo hooo got mine ordered should be here some time next week . It's a shame I had to have mine made/ rebuilt after I got my gt I smashed it trying to get the oversexed battery out of the front and when I took in to have it fixed both my upper and lower tanks were bad. so Gil hooked me up with the tanks and I had the repair folks build me a new 3 row radiator core and added a drain cock. After redoing the entire cooling system it runs cool as a cucumber. But givin you can't just order a new radiator from the local parts store I had to have it not to mention how awesome it looks.Anyone know why the new one calls for 70/30 mix as apposed to the traditional 50/50 ? just curios.
RunOpel
I bought a new radiator from OGTS about 4 years ago and have been using 50/50 with no issues whatsoever. Unless OGTS changed there radiators from 4 years ago, I would think 50/50 is just fine.
too bad I couldn't wait for these to come back or we would still not be driving it total cost for the rebiuld of the radiator was pushing $565.00 OUCH but there were no other options at the time and we weren't waiting any longer than necessary to drive our gt so I guess it was worth it and now we have a back up in the event whether failure acrures or were blessed with another gt. Hoping it's the second option 馃槣 馃お
RunOpel
We do whatever it takes in order to be able to drive our GT's :)
I will guess that the 70/30 mix is to put in more additives in the mix to neutralize the corrosion. AL radiators are far more subject to corrosion that the old brass ones. The reason is simple:
The radiator is connected to the iron block by an electrolyte (the coolant).... Yes, that IS indeed a battery LOL! So you have galvanic corrosion going one with one metal being sacrificial. With a brass rad, the iron in the block is sacrificial; that is why the old brass rads can last so long with crappy maintenance, and the inside of the block and head looked like hexx with rust. BUT, with an AL rad, the aluminum is sacrificial. Not good on the AL rad.
One thing that anyone using an aluminum rad should try do is to completely mount the AL rad in rubber with NO metal connections to the frame anywhere, not even through bolts. The reason is that holding the AL rad completely in rubber will break the battery circuit and slow down the galvanic corrosion. Next time you are under the hood of a modern car with an AL rad, look at how it is mounted. You will almost certaily find that it is completely rubber mounted. Or it will have plastic tanks to break the electrical circuit.
Otherwise, be sure to change you coolant every 2-3 years max with an AL rad with hard metal-to-metal connnections. The additives can get exhausted faster than with a brass rad. And consider using a longer life HOAT coolant, like Zerex G05. Dexcool (OAT coolant) is long life but has its own sludging issues with some older cooling systems.
Did anybody compare cooling ability of Honda 3-row to OGTS HD aluminum radiator? Any experience there? Note, it is Honda 3-row radiator, not a standard 2-row Honda radiator.
1 - 11 of 11 Posts
