my biggest fear on keeping opey alive is if i wreck him.hood/fender/the front end stuff mainly.i have some usable fenders ect but they are out in the weather and will probably rust away in next few years.in looking around i dont find oe or after market---or i missed
is there any intrest in light weight fiber glass(hand layed)fenders/hoods/header
if there is i can clean up the stuff and pull some molds.
based on the race car bodies i make fenders can be as light as 5 to 8lbs
heavier apps would only need another layer of glass.made a light hood for isuzu drag truck for customer that save almost 40lbs(weighed 8lb)
i dont like gel coat as it adds weight and stress cracks sooner than bare glass(no flex)this causes problem to--pin holes to fill in hard to roll out areas.can use gel coat but the weight goes up and the part cost to(more material and labor).gatoring also is problem with gel coat and you dont see it till part is pulled.the only way i have been able to avoid this is thicker gel coat=more weight and material with worse stress cracking.pin holes take time to fill but long tearm results may be better--definatly lighter.
any ideas or input welcome(critics to!)
also have about 5 manta and 2 gts in the field for parts--ask and ill see if i got good part(some parts are stored in building)have 3 more gts located at same spot i am trying to buy.
thanks
David
thanks
David
