Need help with a problem.
Otto has offered advice on this, and sorry Otto, it has not cured the problem. I tried a few different types of fuel filters, even ran without a filter and the problem is still there. It's not the carb, as I have taken a known, good working weber from another car and the problem is still there. Same thing with the fuel pump. The problem is, when I accellerate moderate to hard, the car acts like it has hit a wall (imaginary). The motor wants to rev, and I know these motors will go beyond this point, but, the motor bogs. It's a stock 74 low-comp (7.6:1) with points, no Pertronix, as I have tried the Pertronix with it, and still the problem exsists, and a weber 32/36. The car starts, and idles like a champ, the best running one I have ever had, it's just under hard accelleration, it wants to bog. Normal accelleration is marvelous! It scoots a lot better than most cars I have ever had, but, not when you accellerate hard. It does this from a standing start, and running at speed, although it's not as bad, when at speed, but, it's still there. Any ideas?
