1 - 6 of 6 Posts
Plastic or metal
I have a 1972 Opel GT
Is the part that goes around the steering column suppose to metal or plastic?? There is a metal solid one piece ring on there now that doesnt seem to fit right.
· 4ZUA787
which piece
which piece are we talking about the piece that goes around
were the key cylindar is or the piece behind that. mine goes metal one piece around the key cylindar part is metal and then the piec behind that is plastic i have a 72 gt-al.
The piece that goes around the ignition. Mine is metal and a b**ch to get off and on. Would rather have plastic that splits off.
Having trouble getting it off to change turnsignal ring. Can't seem to get ignition out. Any advice.
Jennifer
I am trying to get to a small gray wire that comes up steering column and into the ignition. This one has been taped up, cause it is fried and I thought I would change it. I think I have to take the ignition out though.
· Reborn Opeler
the small gray wire is for the door buzzer, just cut it off and don't worry about it for it is the negative side of the door switch, remove buzzer and tape up the two wire end connectors at buzzer so they don't short to anything and you'll have solved two problems, burnt wire and damned buzzer.
And please do go to the website
http://www.opel-na.com/
and download the wiring diagrams so you know what I am talking about.
1 - 6 of 6 Posts
