1 - 2 of 2 Posts
I have seen a few threads about people who are planning to pull the engine/tranny using a trans jack as opposed to lowering it out with a hoist.
How did it work? any tips? Can I drop the engine and trans in one piece with this method?
thanks for any info
· Old Opeler
You will just have to lift the whole car up high enough to get the trans jack under the motor/gbox at the balance point. Make sure the car is absolutely rock solid on what ever you prop it up on! :eek:
The method you propose would be very good under a two post car hoist as long as the trans jack is rated high enough to take the weight of the total motor/trans unit ( about 500 pounds ).
1 - 2 of 2 Posts
