I have an Opel GT with a 10 bolt head modified by OGTS to fit the 2.0 Liter Pistons.
I also have the chrome long tube header from OGTS.
The cam is new and is the street strip model form OGTS.
I will be running a brand new 32/36 Webber carb.
My valve cover is chromed as well as the oil pan.
I am concerned about heat soak that I am reading so much about on this website.
I have a new mechanical fuel pump to put in it but I have read that everyone is going to electric fuel pumps.
Questions:
1. What is the recommended fuel pump I should purchase?
2. If I go with an electrical pump, do I need to make a return fuel line back to the tank?
3. If there needs to be a return line, how does it get back to the tank? a new hole or bung added? or plumb it to one of the vent hose inlets?
4. how many are using a fuel pressure regulator with the Webber Carb?
5. What should the regulator pressure be set to if using one.
Once my cam gets broken in, Gil mentioned I should buy a larger Webber 36/38. (I think)
What are everyone's opinion going to the larger carb?
Any help is most appreciated!
Questions:
