1 - 16 of 16 Posts
Certified Opelholic
when I was cleaning out my storage unit I found a 1.9 engine
I was like where did this thing come from
the big thing is it has an aluminum oil pan so that tells me its not a GT engine
can anyone tell me what it came out of and if its a Hi comp or low comp motor
thanks
David
thanks
David
My 71 GT's 1.9 has an aluminum oil pan...
GT's did come with aluminum oil pans. Mine is a 1970 GT 1.9
All my '70-'73 Manta's and Ascona's came with cast aluminum pans (Bad for rallying!) I got a steel one off of a '68 Kadett and the '75 1900 has a steel pan. I'd guess very probably a low compression motor.
Can you get the engine number off the motor? Also, look in the vicinity of the starter motor, where you might find the date when the block was cast.
On the "tab" between the #2 and #3 cylinders is a code starting with 19S. See if there are stars near the 19S
A steel -68 Kadett oil pan ? Do you have a picture ? As far as I know, the only steel Kadett B pan is the ohv one.
All I can tell you is that I pulled it and a whole engine out of a you-pull-it junkyard in Columbus OH back in 1982. It was a Kadett B.... I might be off a year on the model. I remember I was surprised to see it being a steel pan as all I had ever seen to that time were the AL ones. Can't recall if it was a sedan or wagon. I THINK I've still got it somewhere .....
Certified Opelholic
Discussion Starter #10
this one has an Aluminum oil pan with that funky rib thingy at the front
I don't think any GT's had that??
You are correct. Mantas were the only ones.
Certified Opelholic
Discussion Starter #13
ok number on the block
*19S-085653*
dip stick is on the drivers side
and no extra bolts on the front of the head
David
Certified Opelholic
Discussion Starter #16
no I seen these type of oil pans before in junk yards
its just my memory is fading
I had forgot about the GT aluminum oil pans
1 - 16 of 16 Posts
