Hole help need the Down and quick fix dirty fix
Down and dirty fix
Now garageless and among other things I should of fixed while I had a garage I have discovered that the area under my battery exists only to dribble (pour) water onto the fuse box and wiring. Upon further examination I have discovered the area, which previously was under a plate, has more holes in it than the flag that flew above the Alamo.
I know that replacement pieces can be welded on however that takes money so for now until I can get the manta to warmer Climates i need a quick fix as I am in a place that is very wet and the weather is below 50 (actual 40) degrees.
I want a CHEAP temp fix. What would be the best thing to cover the whole area with? Caulk? White silicone? body putty? Glues? liquid weld? rubber cement, fiberglass or another substance? I need something that will hold up for the winter another couple of weeks here in Missouri and then in Las Vegas (where wet weather isn’t quite such a problem). I don’t care about right or pretty for the time being I just need it to stop leaking.
Suggestions?
Bailing in St Louis
Down and dirty fix
Suggestions?
Bailing in St Louis
