1 - 16 of 16 Posts
OPEL PARTS GREECE
Dear Opelers
We would like to inform you that our Campaign 2006 with Opel parts for any model is released
This campaign refers to our genuine and new in stock parts and has 12.406 different detailed code genuine parts consisting of 327 pages which is a small part of our wide spectrum and covers all model type cars in all repair parts range.
E-mail us to send to you our campaign 2006 for free at:
[email protected]
http://img92.imageshack.us/my.php?image=campaignpartsoe3.jpg
We would like also to inform you for our limited stock in the following parts:
126430: TAILGATE KADETT/C
http://img242.imageshack.us/my.php?image=126430af8.jpg
176055: TRUNK LID REKORD/B
http://img242.imageshack.us/my.php?image=176055xe8.jpg
180173: PANEL SIDE OUTER LEFT 2 door KADETT/A
http://img225.imageshack.us/my.php?image=180173fx7.jpg
180180: PANEL SIDE OUTER LEFT 4 door sedan Chassis 36-37 KADETT/B
http://img242.imageshack.us/my.php?image=180180xt7.jpg
183059: PANEL SIDE OUTER LEFT 2 door sedan Chassis 91 KADETT/B
183064: PANEL SIDE OUTER LEFT 2 door sedan Chassis 31-38 KADETT/B
http://img242.imageshack.us/my.php?image=183064li9.jpg
183068: PANEL SIDE OUTER LEFT Coupe super deluxe Chassis 92 KADETT/B
http://img242.imageshack.us/my.php?image=183068hf1.jpg
183143: PANEL SIDE OUTER LEFT MANTA/B
http://img242.imageshack.us/my.php?image=183143eg5.jpg
183168: PANEL SIDE OUTER RIGHT Coupe super deluxe Chassis 92 KADETT/B
http://img242.imageshack.us/my.php?image=183168rw4.jpg
183193: PANEL REAR QUARTER LEFT KW Chassis 64 REKORD/D
http://img242.imageshack.us/my.php?image=183193rj9.jpg
183195: PANEL REAR QUARTER LEFT REKORD/B
http://img242.imageshack.us/my.php?image=183195kd5.jpg
1160322: PANEL BONNET ASCONA/A
1160324: PANEL BONNET KADETT/C
1160331: PANEL BONNET KADETT/C
1160325: PANEL BONNET KADETT/B
http://img242.imageshack.us/my.php?image=1160325id8.jpg
1160326: PANEL BONNET MANTA/B
http://img242.imageshack.us/my.php?image=1160326wk9.jpg
1160328: PANEL BONNET REKORD/D
http://img242.imageshack.us/my.php?image=1160328ox3.jpg
1312237: UPPER PANEL FRONT END 1.5L-1.7L-1.9L KADETT/B
11515 LENS REAR LAMP RIGHT BOSCH ADMIRAL 1
108586 WINDSCREEN WEATHERSTRIP EXC.32 93 KADETT/C ‘74-‘79 2
126430 TAILGATE KADETT/C 5
128482 LETTER ‘’REKORD’’ REKORD/B ‘66 7
170177 WEATHERSTRIP REAR WINDOW MANTA/A 1
172754 MOULDING PROTECTION REKORD 61-62 4
172850 MOULDING REAR WING LEFT REKORD/A 1
176055 TRUNK LID REKORD/B 1
176805 BUMPER HINGE TO LID REKORD/C 20
180173 PANEL SIDE OUTER LEFT 2 door KADETT/A 1
180180 PANEL SIDE OUTER LEFT 4 door sedan Chassis 36-37 KADETT/B 2
183059 PANEL SIDE OUTER LEFT 2 door sedan Chassis 91 KADETT/B 1
183064 PANEL SIDE OUTER LEFT 2 door sedan Chassis 31-38 KADETT/B 1
183068 PANEL SIDE OUTER LEFT Coupe super deluxe Chassis 92 KADETT/B 2
183143 PANEL SIDE OUTER LEFT MANTA/B 1
183168 PANEL SIDE OUTER RIGHT Coupe super deluxe Chassis 92 KADETT/B 2
183193 PANEL REAR QUARTER LEFT REKORD/D 1
183195 PANEL REAR QUARTER LEFT REKORD/B 1
183894 GRILLE VENTILATOR LEFT+ 0183642 MANTA/B ‘76-‘88 2
183895 GRILLE VENTILATOR RIGHT+ 0183642 MANTA/B ‘76-‘88 1
184300 PANEL BODY BACK LOWER KADETT/C 4
302277 DAMPER BUSHING (GM8946351) KAPITAN-ADMIRAL 4
302475 BUMPER STOP UPPER ARM KADETT/A 10
308450 CUP KNUCKLE REKORD 58-62 44
308583 SHAFT ARM FIBER REKORD P-PII ‚58-‚62 20
322044 TIE ROD CENTER REKORD/A-REKORD/B ‚63-‚66 5
324106 STEERING TIE ROD OUTER (LEFT THREAD) REKORD/P-PII-A-B-C ‚58-‚72 140
324107 STEERING TIE ROD INNER (RIGHT THREAD) REKORD/P-PII-A-B-C ‚58-‚72-KADETT/B ‚65-‚73 162
416109 GASKET REAR AXLE HOUSING COVER 19 20 13S 16 18S DIESEL REKORD/A-B-C-D-E-ASCONA/B-MANTA/B ‘63-‘86 5
558088 CYLINDER ASSY BRAKE MAIN REKORD/C 3
578255 BRAKE CABLE FRONT CENTRAL REKORD/C ‘67-‘72 9
607470 GASKET CYLINDER HEAD 6 CYL 2,5L – 2,8L COMMODORE/A-COMMODORE/B 33
607500 GASKET CYLINDER HEAD SIDE COVER 1,7L-1,9L REKORD/A/B 7
607660 GASKET VALVE ROCKER ARM COVER KADETT/B 12
608178 GASKET TIMING HOUSING BACK PLATE REKORD/P-PII-REKORD/A 5
608181 GASKET TIMING HOUSING BACK PLATE REKORD P-PII ‚58-‚62-REKORD/A ‚63-‚65 45
608182 GASKET TIMING HOUSING BACK PLATE KADETT/A-KADETT/B 9
614804 OIL SEAL CRANKSHAFT 82X54X11,4MM KADETT/A-KADETT/B 3
614809 OIL SEAL CRANKSHAFT 77X100X11,45MM KADETT/A-KADETT/B 10
638182 SEAL RING TIMING SPROCKET HOUSING 17,2X12X5,5MM REKORD/A/B-REKORD/ALL-ASCONA-MANTA/ALL 8
638185 SEAL RING TIMING SPROCKET HOUSING 44X58X10MM REKORD/A/B/C/D/E-ASCONA-MANTA 10
638203 TIMING SPROCKET HOUSING 58X44X10MM REKORD/P-PII-REKORD/A 30
638231 GASKET TIMING SPROCKET HOUSING LEFT REKORD/A/B 7
638232 GASKET TIMING SPROCKET HOUSING RIGHT REKORD/A/B 10
638234 GASKET TIMING HOUSING KADETT/A-KADETT/B 12
638641 GASKET CAMSHAFT COVER FRONT AND REAR REKORD/A/B/C/D/E-ASCONA-MANTA/B 10
642452 SEAL VALVE STEM 1,6L-1,7L-1,9L-2,0L-2,2L REKORD/A/B/C/D/E-ASCONA-MANTA 16
646275 GASKET OIL PUMP KADETT/A-KADETT/B 9
646908 GASKET OIL PUMP 15-16-17-19-20 N/S/E-20D (REPL 648408) GT- REKORDA/B/C/D/E-ASCONA-MANTA/ALL-KADETT/C 6
648401 GASKET OIL SUCTION TUBE ON CYLINDER BLOCK 1,5L REKORD/A/B 7
648650 GASKET OIL SUCTION TUBE ON CYLINDER BLOCK (REPL 648533) REKORD ‘53-‘57 5
650451 GASKET OIL FILTER BASE ON CYLINDER BLOCK KADETT/A 2
650453 GASKET OIL FILTER BASE ON CYLINDER BLOCK KADETT/A-KADETT/B 9
656825 GASKET CYLINDER BLOCK VENTILATOR KADETT/A-KADETT/B 12
658125 GASKET OIL LEVEL INDICATOR ROD 1,5L-1,7L REKORD/P-PII-REKORD/A 56
658126 GASKET OIL LEVEL INDICATOR ROD KADETT/A-KADETT/B 13
664128 DISC ASSY CLUTCH 203 DIA (REPL 664121-664099)16 17 19 20N/S REKORD/C-REKORD/D-REKORD/E 30
666018 COVER AND PRESSURE PLATE ASSY KAPITAN 2
666066 CLUTCH PRESSURE PLATE 6 CYLINDER KAPITAN-BLITZ 6
668253 BOOT CLUTCH RELEASE FORK ΚADETT/Α-KADETT/B 30
668254 BOOT CLUTCH RELEASE FORK REKORD/A ‘63-‘65 30
668257 BOOT CLUTCH RELEASE FORK A/B M/B 16 19 20 R/E 18 ΟΛΑ 10
668261 BOOT CLUTCH RELEASE FORK 1,3L ASCONA/B-MANTA/B 5
732653 BUSHING TRANS.SELECTOR SHIFT LEVEL REKORD 58-63 14
738900 GROMMET RUBBER GEARSHIFT CONTROL UPPER KADETT/ALL-ASCONA-MANTA/ALL-REKORD/A-B-C-D-E ‘63-‘86 10
738901 RUBBER RING BOOT KADETT/C-ASCONA-MANTA/ALL 15
766351 GROMMET GEARSHIFT CONTROL REKORD 58-62 10
808170 FUEL TANK CAP PRIMER GT-REKORD/D-ASCONA/A-MANTA/A ‘69-‘74 10
818125 GASKET FUEL PUMP VALVE PLATE 1,7L REKORD/P-PII-REKORD/A 50
818605 GASKET FUEL PUMP FLANGE CENTER KADETT/A-KADETT/B 10
818606 GASKET FUEL PUMP FLANGE OUTER KADETT/A 24
818610 GASKET FUEL PUMP FLANGE OUTER REKORD ‘53-‘57 2
818618 GASKET FUEL PUMP FLANGE CENTER 1,5L REKORD/A/B 3
830832 GASKET CARBURETTOR 12 13N 16N 19N KADETT/A-KADETT/B-KADETT/C-ASCONA-MANTA/B 18
832524 GASKET CARBURATOR TO INDUCTION MANIFOLD KADETT/A-KADETT/B-KADETT/C-ASCONA-MANTA/B 2
832527 GASKET CARBURATOR TO INDUCTION MANIFOLD REKORD/A/B-C-D 1
832528 GASKET CARBURATOR TO INDUCTION MANIFOLD PAPER REKORD/A/B-C-D 1
832535 GASKET CARBURATOR TO INTAKE MANIFOLD 12 13Ν 16Ν 19Ν REKORD/A/B-C-D-ASCONA-MANTA/B 12
832535 GASKET INDUCTION 12 13Ν 16Ν 19Ν ASCONA-MANTA 12
846441 HOUSING ACCELERATOR CONTROL 0848605 NEO KADETT/B-KADETT/C 16
850624 GASKET BETWEEN INTAKE –EXHAUST MANIFOLD REKORD/A/B-C-D-E-ASCONA-MANTA/B 12
850688 GASKET INTAKE –EXHAUST MANIFOLD TO CYL. HEAD 1,5L OLYMPIA ‘53-‘57 3
850695 GASKET INTAKE MANIFOLD TO CYLINDER HEAD KADETT/A ‘63-‘65 22
850696 GASKET EXHAUST MANIFOLD TO CYLINDER HEAD KADETT/A-KADETT/B 16
850700 GASKET EXHAUST MANIFOLD TO CYLINDER HEAD 1,5L REKORD/A/B 2
854835 GASKET EXHAUST PIPE FLANGE 1,5L-1,7L REKORD/A/B-REKORD/C-D-ASCONA-MANTA/B 3
1101112 FRONT WING LEFT>>>84 REKORD/E 12
1101655 CHROME 6
1102080 FRONT WING RIGHT MANTA/A 1
1102099 FRONT WING RIGHT ASCONA/B 1
1102112 FRONT WING RIGHT >’84 REKORD/E 12
1160322 PANEL BONNET ASCONA/A 4
1160324 PANEL BONNET KADETT/C 4
1160325 PANEL BONNET KADETT/B 4
1160326 PANEL BONNET MANTA/B 4
1160328 PANEL BONNET REKORD/D 1
1160331 PANEL BONNET KADETT/C 2
1211036 IGNITION DISTRIBUTOR 6 CYLINDER BLITZ-COMMODORE-KAPITAN 1
1212206 DISTRIBUTOR ROTOR-BOSCH GT-REKORD/C-D-E-KADETT/ALL-ASCONA-MANTA/B 44
1212652 GASKET DISTRIBUTOR (REPL 1212254) REKORD/A-B-C-D-ASCONA-MANTA/B-KADETT/C 11
1218252 LENS HEADLAMP KAPITAN '56 1
1218275 LENS HEADLAMP ADMIRAL 7
1223197 HOUSING REAR LENS RIGHT COMMODORE/B 1
1223360 LENS REAR LAMP LEFT COMMODORE/B 4
1223372 LENS REAR LAMP LEFT 4DOOR (REPL 1223350) REKORD/D '73-'77 10
1223373 LENS REAR LAMP RIGHT 4DOOR (REPL 1223351) REKORD/D '73-'77 10
1223382 LENS REAR LAMP LEFT 4DOOR (REPL 1223380-1223152-1223327) ASCONA/A '69-'74 7
1223383 LENS REAR RIGHT (REPL 1223325-1223329-1223382) ASCONA/A '69-'74 4
1223390 LENS REAR LAMP RIGHT SALOON KADETT/B 5
1224252 LAMP LENS REAR LEFT SALOON REKORD/C '67-'72 1
1224253 LAMP LENS REAR RIGHT SALOON REKORD/C '67-'72 1
1224349 LENS REAR LAMP RED/GLEAR GLASS REKORD/B '66 2
1224441 REAR LAMP GASKET KADETT/B 4
1226303 HOUSING FRONT TURN SIGNAL LAMP LEFT (REPL 1226294) ASCONA/A 3
1226304 HOUSING FRONT TURN SIGNAL LAMP RIGHT (REPL 1226296) ASCONA/A 8
1226350 LENS YELLOW LEFT KADETT/A '63-'65 13
1226351 LENS YELLOW RIGHT KADETT/A '63-'65 30
1226356 LENS FRONT DIR.SIGNAL LAMP YELLOW LEFT REKORD/A-REKORD/B '63-'66 3
1226359 LENS FRONT DIR.SIGNAL LAMP YELLOW RIGHT REKORD/A-REKORD/B '63-'66 18
1242035 BOW SIGNAL HORN LESS CUSHION COMPLETE (REPL 1242332) REKORD/C-COMMODORE/A 2
1312327 UPPER PANEL FRONT END 1.5L-1.7L-1.9L KADETT/B 2
1312382 UPPER PANEL FRONT END ASCONA/A
1334729 GASKET WATER PUMP COVER 1,7L REKORD/P-PII-REKORD/A 48
1334731 GASKET WATER PUMP ON CYLINDER BLOCK KADETT/A-KADETT/B-KADETT/ALL-ASCONA-MANTA/ALL 13
1334734 GASKET WATER PUMP COVER 1,5L-1,7L REKORD/A-B-C-D 10
1336560 GASKET WATER PUMP ON CYLINDER BLOCK 1,5L REKORD/A/B 12
1336748 HOSE RADIATOR UPPER 1,5-1,7-1,9L ΚADETT/Β-REKORD/C 30
1336782 HOSE RADIATOR UPPER ASCONA-MANTA/A-ASCONA-MANTA/B-REKORD/C-D-E 11
1338209 GASKET THERMOSTAT HOUSING ON CYLINDER BLOCK 1,5L REKORD/A/B 23
1604073 FRONT JOINT SHAFT AXLE DRIVE U 715 REKORD '58-'65-ASCONA-MANTA/A 32
1604074 REAR JOINT SHAFT AXLE DRIVE U 710 REKORD '58-'65 20
1604078 REAR JOINT SHAFT AXLE DRIVE U702 REKORD/C 50
1606228 OIL PAN GASKETS SET (RP-652-10) KADETT/A-KADETT/B 14
1606230 OIL PAN GASKETS SET 1,6L-1,7L-1,9L-20N/S-20D (RP-652-012) REKORD/A-B-C-D-ASCONA-MANTA-K/C 20
1608004 FUEL PUMP REPAIR SET PIERBURG (RP-816-007) (REPL 1608008) GT-REKORD/A-B-C-KAP-COMMO-BLITZ 34
1608008 FUEL PUMP REPAIR SET (REPL RP 816-04-RP-816-007) GT-REKORD/A-B-C-KAP-COMMO-BLITZ 26
1608013 CARB.REP. SET FOR 816013 (RP-826-064-826-052) (REPL 1608035) GT-REKORD/A-B-C 41
1608023 CARBURATOR REPAIR SET(REPL 1608035) (R826052/064) GT-REKORD/A-B-C 22
1608039 SET JETS CARBURETOR (REPL 1608230) 1,7L-1,9L REKORD/C 10
1608044 CARBURATOR REPAIR SET (RP-826-073) 2,5L COMMODORE/A-B 9
1608129 FUEL PUMP REPAIR SET FOR 816025-816026 A/C REKORD/A-B-C-D-ASCONA-MANTA-KADETT/B-C-BLITZ 12
1612129 LENS & HOUSING CPL FRONT DIR.SIGNAL LAMP YELLOW RIGHT REKORD/A-REKORD/B '63-'66 8
1612258 LAMP ASSY.REAR LEFT 300637/SWF (REPL 1612322) ASCONA/A '69-'74 14
1612259 LAMP ASSY.REAR RIGHT 300636/SWF (REPL 1612323) ASCONA/A '69-'74 6
1612386 LAMP ASSY REAR LEFT SALOON (REPL 1612284) REKORD/D '73-'77 40
1612387 LAMP ASSY REAR R SALOON (300822) (REPL 1612285) (1223198+1223351) REKORD/D '73-'77 25
1612390 LAMP ASSY REAR LEFT COMMODORE (13-19) (1223360+1223197) COMMODORE/B 4
1612391 LAMP ASSY REAR RIGHT COMMODORE (13-19) (1223361+1223198) COMMODORE/B 4
1710399 CRYSTAL LENS ADMIRAL-KAPITAN 1
2091016 SEAL RING OIL DRAIN SCREW 1,5L REKORD/A/B 25
2091018 SEAL RING OIL DRAIN SCREW 21,9X16,2X2MM REKORD/A/B 6
2091029 SEAL RING OIL DRAIN SCREW 1,7L 32,3X37,9X2,5MM (N 42650) REKORD/P-PII-REKORD/A 23
2091046 SEAL RING OIL DRAIN SCREW 20X14X2,5MM KADETT/A-KADETT/B-ALL 10
6424294 HOSE ALL 11
6683504 CAMSHAFT 6 CYLINDER 1
8040030 RADIATOR HOSE 4
8941961 INSIDE RUBBER BOOT 2
RP 816-04 FUEL PUMP REPAIR SET (REPL 1808008) OLYMPIA/A - GT 5
In case of interest please inform us a.s.a.p.
Also if you are familiar with part numbers we can send you the list of parts that are not translated yet
Believing that our services could constitute one still useful tool for Opel parts supply we will wait for your news.
Our best & warm greetings from Greece
Sincerely yours
Anthony Drosos
Opel spare parts sales / Export Manager
E-mail: [email protected]
OPEL PARTS GREECE
Discussion Starter #2
Dear Opelers
[email protected]
312185: COIL SPRING FRONT 1,6L-1,9L-2,0L 11.9mm ASCONA/A,B - MANTA/A,B
312187: COIL SPRING FRONT 1,6L-1,9L-2,0L 12.4mm ASCONA/A,B - MANTA/A,B
312186: COIL SPRING FRONT 1,2L-1,3L ASCONA/A,B - MANTA/A,B
312188: COIL SPRING FRONT 1,6L-1,9L-2,0L H/D ASCONA/A,B - MANTA/A,B
312195: COIL SPRING FRONT 1,6L-1,9L-2,0L DIESEL ASCONA/B
424248: COIL SPRING REAR 1,6L-1,9L-2,0L ASCONA/A,B - MANTA/A,B
1101655 CHROME 6
6424294 HOSE ALL 11
Sincerely yours
Anthony Drosos
OPEL PARTS GREECE
Discussion Starter #3
Dear Opelers
[email protected]
1101655 CHROME 6
6424294 HOSE ALL 11
Sincerely yours
Anthony Drosos
OPEL PARTS GREECE
Discussion Starter #4
Dear Opelers
[email protected]
1101655 CHROME 6
6424294 HOSE ALL 11
Sincerely yours
Anthony Drosos
E-mail: alph[email protected]
1958 Opel Caravan
Hi - do you have the lens (2 - left & right) for the front parking/side lights ? What's your price and shipping by air ? Thank you.
Malcolm Logan Chiangmai Thailand
Good to Deal With
I bought a camshaft for my 1967 Kadett "SR" motor here and was very impressed with the professional service ... and how amazingly inexpensive the Air Mail postage was. Well woth checking through these parts or contacting Anthony Drosos if you need a nice new part.
The parts are quite expensive - comparible with Opel new parts - but they are genuine Opel parts.
Opel Classics
Thanks GTJIM - I posted 3 months ago and didn't get a reply. I've posted again today and I sent an email direct as well. I hope this time to have an answer.
Good to know there IS a genuine supplier out there - not just a poster of lengthy emails of Opel parts.
Malcolm Logan
Detroit,where my home was
What a list of parts, only one thing I HATE: to search thru miles of text with every sentence an other model.
Anthony isn't it possible to make a list with only one model?? Or if two models are based upon each other like the Ascona/Manta or C Rekord/A Commodore, a list with both models??
Would make finding the right part for our cars a lot easier?[just a thought]
tomking
Parts to Buy
Alpharm, my email system does not like your address and it wont let me email you a message. Please PM me here if you are not getting an email from me inquiring about purchasing a carb. Thanks.
OPEL PARTS GREECE
Discussion Starter #12
CAMPAIGN July 11
110274 90295523 WEATHERSTRIP, WINDSCREEN KADETT/E 1
110408 8973302 CONNECTOR, WINDSCREEN MOULDING KADETT/C-D 3
110455 8983284 WINDOW SAFETY CHROME PER METER KADETT/B-C-ASCONA-MANTA/A-B-REKORD/D 8
110458 90166107 MOULDING, BACK WINDOW , ANTHRACITE METER KADETT/C-ASCONA-MANTA/B-ASCONA/C 12M
110536 90158329 CONNECTOR, WINDSCREEN MOULDING, REAR END PANEL, LOWER, ANTHRACITE ASCONA/C 1
114493 3438705 BUMPER RUBBER STOP ASCONA/B 4
128458 90510531 EMBLEM, OPEL REAR CHROME 104-78 TIGRA/A 1
129471 90227069 NAMEPLATE, OPEL, GREY/BLACK KADETT/E 1
129473 90219587 EMBLEM REAR GRAY (SELF-ADHESIVE STICKER) (GSI GT) KADETT/E 5
129572 90321507 EMBLEM BLACK 75MM (REPL 177746) (M4000001-) VECTRA/A-CORSA/A 2
133381 90141102 A/C R/E 364 A/C R/E 3
133384 90167273 BARREL & KEY (REPL 133355) ASCONA-MANTA/B-KADETT/C-KADETT/D 1
133750 3466677 SEAL LOCK BARREL (REPL.177403) A/B M/B K/C KADETT/D-KADETT/E-ASCONA/C 6
133861 8972651 HOUSING LOCK BARREL KADETT/C ASCONA/B-MANTA/B 5
133871 90113676 HOUSING LOCK BARREL (REPL 177429) KADETT/D 2
133880 3466853 SPRING LOCK BARREL A/B M/B K/C KADETT/D-KADETT/E-ASCONA/C 4
133881 90043381 SPRING LOCK BARREL REKORD/E 16
133882 90069940 SPRING RETAINING LOCK BARREL K/C Α/Β Μ/Β KADETT/D-KADETT/E-ASCONA/C 6
133907 90053635 LINK CONTROL LOCK BARREL LEFT ASCONA-MANTA/B-KADETT/C 3
133908 90053636 LINK CONTROL LOCK BARREL RIGHT KADETT/C-ASCONA/B-KADETT/D '79-'84 8
133981 90053649 RING SNAP LOCK BARREL ASCONA/B-MANTA/B 4
134019 90018803 LOCK FRONT DOOR LEFT ΑSCONA-ΜANTA/Β-ΚADETT/C-K/D-A/C-R/E 6
134020 90018800 LOCK FRONT DOOR RIGHT ΑSCONA-ΜANTA/Β-ΚADETT/C-K/D-A/C-R/E 7
134533 3440522 SEAL RING DOOR LOCK REKORD/E-KADETT/C-KADETT/D-ΑSCONA/Α-ΑSCONA/Β-C 3
134618 90053650 DOG LOCK BARREL A/B M/B K/C R/E A/C K/D K/E 7
136541 9287258 ESCUTCHEON HANDLE SAFETY 55 59 ΜANTA/Β 4
138092 8972648 HANDLE GRIFF RIGHT CHROME ASCONA-MANTA/B-KADETT/C-KADETT/D-ASCONA/C 1
140401 2885843 REGULATOR FRONT DOOR WINDOW L (+R) KADETT/B 4DOORS 7
142374 9278019 DOOR CRANK HANDLE CHROME ASCONA-MANTA/A-KADETT/B-REKORD/C 7
146320 2885824 COLLAR REAR QUARTER WINDOW VENTILATOR KADETT/C-ASCONA-MANTA/B 19
148000 148000 WEATHERSTRIP INNER WINDOW SEAL; OPEL 1
148164 8972611 WINDOW RUBBER SEAL 4DOOR KADETT/C 4DOOR 3
148187 9282922 CHANNEL WINDOW RUN RIGHT 2DOOR-4DOOR 1370L ASCONA/B 1
148190 9282794 WEATHERSTRIP CHANNEL WINDOW FRONT SIDE LEFT & RIGHT MANTA/B '76-'88 2
148190 9282794 WEATHERSTRIP CHANNEL WINDOW FRONT SIDE LEFT & RIGHT MANTA/B '76-'88 1
149200 9283981 CORNER FILLER DOOR WINDOW RAIL OUTER LEFT ASCONA/B '75-'81 3
149205 9283982 CORNER FILLER DOOR WINDOW RAIL OUTER RIGHT ASCONA/B 1
152000 9283015 WEATHERSTRIP REAR QUARTER WINDOW LEFT MANTA/B '76-'88 2
152001 9283016 WEATHERSTRIP REAR QUARTER WINDOW RIGHT MANTA/B '76-'88 2
152004 9282817 WEATHERSTRIP REAR QUARTER WINDOW L & R OPENING ASCONA/B-MANTA/B '75-'88 4
152107 90110997 WEATHERSTRIP REAR QTR WINDOW OPENING 3D GTE KADETT/D 6
152149 90186653 WEATHERSTRIP, REAR QUARTER VENTILATION, LH (OPENING) KADETT/E 1
152150 90186654 WEATHERSTRIP, REAR QUARTER VENTILATION, RH (OPENING) KADETT/E 1
154236 8974403 WEATHERSTRIP FRONT INNER LEFT 2 DOORS COUPE KADETT/C 3
154239 8974404 WEATHERSTRIP FRONT INNER RIGHT 2 DOORS COUPE KADETT/C 3
154241 8974408 WEATHERSTRIP REAR INNER RIGHT 4 DOORS KADETT/C 4
154242 8974331 WEATHERSTRIP FRONT OUTER LEFT 2 DOORS COUPE KADETT/C 3
154245 8974332 EATHERSTRIP FRONT OUTER RIGHT 2 DOORS COUPE KADETT/C 3
154278 90069749 WEATHERSTRIP FRONT LEFT INNER 4D 5D VAN KADETT/D 1
154281 90069786 WEATHERSTRIP REAR RIGHT INNER KADETT/D 1
154284 9289169 WEATHERSTRIP FRONT INNER LEFT 4 DOORS ASCONA/B 3
154288 9289167 WEATHERSTRIP FRONT INNER LEFT 915MM (REPL 154262-154263-154289) MANTA/B 1
154289 9289168 WEATHERSTRIP FRONT INNER RIGHT 915 ΜΜ (REPL 154262-154263-154288) MANTA/B 1
154297 90035333 WEATHERSTRIP FRONT LEFT & RIGHT OUTER ASCONA/C 1
154318 90186562 FRONT DOOR WINDOW RECESS WEATHERSTRIP, INNER, RH KADETT/E 3
156700 9282823 MOULDING ROOF FRONT LEFT MANTA/B 2
156701 9282824 MOULDING ROOF FRONT RIGHT MANTA/B 2
156907 90078130 WEATHERSTRIP TAIL GATE KW-CITY (REPL 156906) 3920CM KADETT/C-D 2
157300 90018935 WEATHERSTRIP REAR DOOR RIGHT REKORD/E 1
157312 90069702 WEATHERSTRIP DOOR LEFT & RIGHT 2DOOR GTE 31-33 KADETT/D 3
157342 90148291 WEATHERSTRIP REAR DOOR LEFT D….. REKORD/E 1
157343 90148292 WEATHERSTRIP REAR DOOR RIGHT REKORD/E 1
157355 90019614 WEATHERSTRIP 3RD DOOR KW REKORD/E 1
164361 90033713 RIVET ALL 49
164822 8972164 SILL PANEL MOULDING CHROME KADETT/C 16
164828 90124849 SILL PANEL MOULDING BLACK ASCONA/C 4
166103 8976945 SLIDER SEAT INNER L & R KADETT/C '74-'79 2
166109 3437649 SLIDER SEAT OUTER L & R KADETT/C-ASCONA-MANTA/B 12
167251 90040873 SEAT GUIDE RAIL CLIP KADETT/D-ASCONA/C 8
167251 90040873 SEAT GUIDE RAIL CLIP KADETT/D-ASCONA/C 38
171705 90254562 MOULDING, PROTECTION, BLUE/GREY, FRONT DOOR, RH ASCONA/C 5
172070 9282751 MOULDING PILLAR FRONT LEFT ASCONA/B 7
172071 9282752 MOULDING PILLAR FRONT RIGHT ASCONA/B 2
172504 9288818 MOULDING PROTECTION FRONT DOOR RIGHT 4DOORS ΑSCONA/B 1
172505 9288819 MOULDING PROTECTION REAR DOOR LEFT 4DOORS ASCONA/B 1
172601 90179827 MOULDING GSI DOOR LEFT K/E 2D GSI CABRIO 1
172602 90179828 MOULDING GSI DOOR RIGHT K/E 2D GSI CABRIO 1
172603 90179829 MOULDING GSI REAR QTR PANEL LEFT K/E 2D GSI CABRIO 1
172604 90179830 MOULDING GSI REAR QTR PANEL RIGHT K/E 2D GSI CABRIO 1
172674 90257131 MOULDING, REAR DOOR, LH, BLUE/GREY, WITH SILVER STRIPE G-K KADETT/E 5
172714 9282759 MOULDING DOOR LEFT MANTA/B 1
172715 9282760 MOULDING DOOR RIGHT MANTA/B 1
172726 8975491 MOULDING DOOR 2 DOOR COUPE KW KADETT/C 1
172738 90045315 MOULDING LEFT 2 DOOR REKORD/E 11
172799 90237340 NAMEPLATE "MANTA GSI" MANTA/A-B 6
172854 2885963 MOULDING REAR WING LEFT KADETT/B 1
172855 2885964 MOULDING REAR WING RIGHT KADETT/B 1
172915 90045317 MOULDING REAR QUARTER PANEL FRONT LEFT 2D-3D REKORD/E 2
172916 90045318 MOULDING REAR QUARTER PANEL FRONT RIGHT 2D-3D REKORD/E 2
172919 90045325 MOULDING, PROTECTION, REAR QTR PANEL LEFT REKORD/E 5
173025 9286521 MOULDING REAR WING LEFT FRONT PART MANTA/B 5
173029 9286523 MOULDING REAR QUARTER PANEL LEFT REAR PART MANTA/B 6
173030 9286524 MOULDING REAR QUARTER PANEL RIGHT REAR PART MANTA/B 11
173516 90035239 FRONT DOOR WINDOW FRAME MOULDING, REAR, CHROME, LH ASCONA/C 4
173545 90044666 MOULDING REAR RIGHT DOOR REKORD/E 5
173545 90044666 CHROME MOULDING REAR DOOR RIGHT REKORD/E 5
173550 90062729 CHROME MOULDING REAR DOOR LEFT REKORD/E 2
173553 90062728 MOULDING REAR DOOR RIGHT REKORD/E 5
173668 9288100 CHROME MOULDING DOOR LEFT 2D-KW REKORD/E 1
173670 9288102 MOULDING REAR RIGHT DOOR (+173672) ASCONA/B 2
173688 90014659 MOULDING FRONT LEFT DOOR 2D VAN REKORD/E 3
173688 90044659 CHROME MOULDING DOOR LEFT 2D-KW REKORD/E 1
173689 90044660 MOULDING FRONT RIGHT DOOR 2D VAN REKORD/E 4
173689 90044660 CHROME MOULDING DOOR RIGHT 2D-KW REKORD/E 2
173762 90044790 CHROME MOULDING WITH WINDOW WEATERSTRIP FRONT RIGHT DOOR REKORD/E 3
173778 90069742 CHROME MOULDING DOOR KADETT/D 2
173794 90035323 REAR DOOR OUTER WAIST MOULDING, CHROME, LH ASCONA/C 2
173795 90035324 REAR DOOR OUTER WAIST MOULDING, CHROME, RH ASCONA/C 5
174332 8974689 MOULDING REAR PANEL BLACK/ALUMINUM KADETT/C 3
174618 3469416 CLAMP MOULDING ASCONA-MANTA/ALL-KADETT/ALL-REKORD/ALL 31
174721 3439330 CLAMP MOULDING ASCONA-MANTA/B-ΚADETT/D-ΑSCONA/C 31
174722 3438722 CLAMP MOULDING ASCONA/A-MANTA/A-ASCONA/B-MANTA/B 20
174851 90355565 CLAMP, MOUNTING PROTECTION MOULDING CALIBRA 3
175006 90062731 MOULDING L VENTILATION SIDE PANEL D……. REKORD/E- CARLTON 5
175007 90062732 MOULDING R VENTILATION SIDE PANEL D……. REKORD/E- CARLTON 5
176343 6698125 LOCK TRUNK LID Κ/Β K/C A/B R/E M/B R/D C/A(A/C 2
176343 6698125 LOCK TRUNK LID Κ/Β K/C A/B R/E M/B R/D C/A(A/C 1
176735 90053189 CLAMP NAMEPLATE KADETT/D 60
176805 90241734 BUMPER, HINGE, TRUNK LID STOP ASTRA/F KADETT/E OMEGA/A 9
177009 90127767 NAMEPLATE "OPEL" CHROME/BLACK (REPL 177611) CORSA/A 1
177157 90094108 BARREL AND KEYS TRUNK LID (REPL 177158) KADETT/C-KADETT/D-ASCONA-MANTA/B 1
177161 90094112 BARREL AND KEYS TRUNK LID REKORD/E '78-'86 1
177423 90104633 HOUSING LOCK BARREL TRUNK LID KADETT/C-ΑSCONA/Β-ΜANTA/Β 10
177480 8944560 RING SNAP REAR TRUNK LID LOCK ALL 3
177501 8972045 CLAMP LOCK REAR HOUSING ALL 3
177501 8972045 CLAMP-SPRING ALL 1
177530 9285288 RING SEAL HOUSING ALL 16
177582 90413036 EMBLEM, OPEL REAR 75MM N…..R ASTRA/F 2
177611 90444435 NAMEPLATE, OPEL KADETT/E 1
177746 90464665 EMBLEM OPEL (REPL 129572) 75MM BLACK P…… VECTRA/A-CALIBRA 1
177855 9286903 LETTER "SR" ΑSCONA/B-MANTA/B 4
177972 90104681 NAMEPLATE "ASCONA" BLACK ASCONA/C 2
178037 90120284 CAP BODY K/D K/C C/B Ο-D 08.1 5
178070 90389529 CAP BODY O-D 20.0 ALL 2
179366 90062365 CONSOLE BLACK REKORD/E 4
179487 90163658 CONSOLE BROWN REKORD/E 1
182804 8974857 GAS TANK DOOR HINGE KW KADETT/C 2
182805 8974858 GAS TANK DOOR HINGE ALL KADETT/C 4
182884 90045899 SEAL RING FLAP FUEL FILLER REKORD/E-ASCONA/B-ASCONA/C 5
183245 90020130 PANEL REAR QUARTER RIGHT 4 DOORS ASCONA/B 2
183882 8968313 GRILLE VENTILATOR LEFT MANTA/A 4
183951 90043382 REAR PANEL SALOON REKORD/E 1
183970 90078144 REAL PANEL HATCH MANTA/B 1
191197 9283912 ROOF SEAL SLIDING 20Χ840 ASCONA/MANTA/B-ASCONA/C 1
222075 90124648 CROSSMEMBER ASSY FRONT (HD)13NS, 16N,S,SV,LZ, E18NV, S18NV, 16D,DA KADETT/D ASCONA/C 1
222076 90124649 CROSSMEMBER ASSY FRONT 13N,S, 16N,S,SV,LZ, E18NV, S18NV, 16D,DA KADETT/D ASCONA/C 1
310116 8983491 UPPER CONTROL ARM LEFT (REPL 310109) ASCONA/Α-MANTA/A 3
310117 8983492 UPPER CONTROL ARM RIGHT (REPL 310110) ASCONA/Α-MANTA/A 1
310128 90017465 UPPER CONTROL ARM LEFT ΑSCONA-MANTA/Β 4
310129 90017466 UPPER CONTROL ARM RIGHT ΑSCONA-MANTA/Β 4
310452 6696794 DAMPER RING UPPER CONTROL ARM FRONT REKORD/A-REKORD/B-REKORD/C '63-'72 73
310453 6696793 DAMPER RING UPPER CONTROL ARM REKORD/A-REKORD/B-REKORD/C '63-'72 62
310457 8982375 DAMP BUSH FRONT UPPER CNRL ARM FRONT (REPL 310462) KADETT/C-ASCONA-MANTA/B 5
310458 8982376 DAMP BUSH FRONT UPPER CNRL ARM REAR (REP 310463) KADETT/C-ASCONA-MANTA/B 10
322129 90188426 ROD TIE CENTER 1,7-1,9-2,0-2,2E REKORD/E-COMMODORE C 1
322145 90369125 ROD TIE CENTER C24NE 23YD 23YDT 23DTR OMEGA/A 1
322168 90510650 ROD, ASSY., TIE, OUTER, RH (REPL 322160)……X OMEGA/B 1
322169 90510649 ROD, ASSY., TIE, OUTER, LH (REPL 322159)…....X OMEGA/B 1
322171 90510639 JOINT, ASSY., OUTER, LH (SHORT) (REPL 322151) OMEGA/A-SENATOR B 1
322172 90510640 JOINT, ASSY., OUTER, RH (SHORT) (REPL 322154) OMEGA/A-SENATOR B 1
322175 90510643 JOINT, ASSY., OUTER, LH (LONG) (REPL 322150) OMEGA/A-SENATOR B 1
322176 90510644 JOINT, ASSY., OUTER, RH (LONG) (REPL 322152) OMEGA/A-SENATOR B 1
324036 90094762 END ASSY TIE ROD LEFT TILL CHASSIS KADETT/D 2
324037 90094763 END ASSY TIE ROD RIGHT TILL CHASSIS KADETT/D 1
324040 90140432 END ASSY TIE ROD LEFT FROM CHASSIS KADETT/D 4
324041 90140433 END ASSY TIE ROD RIGHT FROM CHASSIS KADETT/D 3
324045 90188428 TIE ROD END INNER L & R SHORT REKORD/E 2
328022 11070311 BEARING WHEEL INNER ALL RWD 1
328410 90217059 BEARING WHEEL SEAL. L+R 40mm ASCONA-MANTA/B-REKORD/E-KADETT/C 4
350096 3455487 BUMPER RUBBER FRONT STABILIZER SHAFT TO ARM ASCONA-MANTA/A 2
352305 6696800 DAMPER BUSHING LOWER CONTROL ARM REKORD/A-B-C 7
352314 9290046 DAMPER BUSHING LOWER CONTROL ARM C….>> REKORD/D 2
352335 90235040 BUSH, DAMPER, FRONT SUSPENSION ARM, LOWER, REAR KADETT/E 1
352349 90335966 DAMPER BUSHING LOWER CONTROL ARM FRONT KADETT/D KADETT/E 6
352355 90373854 DAMPER BUSHING LOWER CONTROL ARM (REPL 352343) OMEGA/A 2
352805 HEYD-LEMF GUIDE JOINT LOWER CONTROL ARM (REPL 352806) L+R 41X13,5XM12 KADETT/A-KADETT/B 1966 COUPE 1
352811 HEYD-LEMF GUIDE JOINT LOWER CONTROL ARM 4587478>> ΄70-'71 (45-11-Μ14=22ΜΜ NUT) REKORD/C 23
352813 HEYD-LEMF GUIDE JOINT LOWER CONTROL ARM <<4587477 '67-'70 (45-11-M12-19MM NUT) REKORD/C 27
352814 HEYD-LEMF GUIDE JOINT LOWER CONTROL ARM (REPL 352807) 43,5X15XM14 REKORD/A-REKORD/B-KADETT/B '66-'71 1
352815 HEYD-LEMF GUIDE JOINT LOWER CONTROL ARM (REPL.352819) 43,5X17XM14 ASCONA-MANTA/B-REKORD/D-COMMO 2
353409 9291672 DAMPER BUSHING ASCONA-MANTA-B-KAD-C 2
371007 90086219 GEAR, SPEEDOMETER DRIVING (26 TEETH) C/A-B K/E-A/F-V/A-A/C 2
406560 2865860 TENSION RING DRIVE PINION 10 12 13N 16N KADETT/B-C '66-'79-ASCONA/A-B-MANTA/A-B 2
406562 2887654 TENSION RING DRIVE PINION 16-17-19-20 KADETT/B-C '66-'79-ASCONA/A-B-MANTA/A-B 7
406753 8967818 DRIVE PINION OIL SEAL REC/B-C-D-Ε 2
406753 8967818 DRIVE PINION OIL SEAL REC/B-C-D-Ε 3
408812 8777340 DISK LIMITED SLIP DIFFERENTIAL REKORD/C-D-E-COMMO 2
408813 8977341 DISK LIMITED SLIP DIFFERENTIAL REKORD/C-D-E-COMMO 4
408843 8977343 DISK LIMITED SLIP DIFFERENTIAL REKORD/C-D-E-COMMO 3
410225 8967305 HOUSING DIFF.RING FOR 33:9-35:9-38:9-37:10 ASCONA-MANTA/A-B REKORD/D-E 2
410903 8967955 CUP SPRING WASHER ASCONA-MANTA/B 2
414385 6695783 RETAINER RING REAR AXLE SHAFT BALL BEARING 17N 18N/S 19N 20 REKORD/A-B-C-D-E '63-'86 25
414552 8940587 RING REAR AXLESHAFT BALL BEARING RUBBER 1,3L-1,6L-1,8L-2,0L DIES ASCONA/A-B-MANTA/A-B-REKORD/E 4
417200 2893387 DAMPER BUSHING ROD CONNECTING REAR AXLE KADETT/B-C-ASCONA/B-MANTA/B -REKORD/E 6
444182 3431255 DAMPER CENTER REAR STABILIZER SHAFT (REPL.350111) KADETT/B-C-ASCONA-MANTA/B 4
444336 90343305 BUSH, SHACKLE (REPL 444325) CALIBRA-OMEGA/A-SENATOR/B 4
458367 90578558 COUPLING, RUBBER, 50 X 127/131 X 30 U25TD 25 30 OMEGA/A-B-FRONTERA 1
464310 90079177 DAMPER BUSHING LOWER CONTROL ARM REKORD/E 2
464312 90125773 DAMPER BUSHING LOWER CONTROL ARM REAR DIES. 18N/S C18NV 20S/E 22E REKORD/E 2
OPEL PARTS GREECE
Discussion Starter #13
522525 90002397 BRAKE CABLE REAR 1,0L-1,2L KADETT/C 2
522555 90193364 HANDBRAKE CABLE 2664mm ΑSCONA/Β ΜANTA/Β 3
545704 90215293 SEAL RING PUMP TO DRIVE SHAFT A/C K/D K/E 16D Α/F X17DTL -P 3
550056 3469210 CULINDER ASSY REAR BRAKE 5/8 16MM ASCONA-MANTA/A-REKORD/C-REKORD/D-E 2
550305 0 CUP REAR WELL BRAKE CYLINDER 03.3402-2501.1 REKORD '58-'62-REKORD P-PII '58-'62-REKORD/A '63-'65 318
550311 2866169 REAR WHEEL BRAKE CYLINDER SEAL 5/8 12 13N 16N KADETT/C-D-ASCONA-MANTA/B 2
550315 0 CUP REAR WELL BRAKE CYLINDER REKORD 58-62 304
550322 90168029 REAR WHEEL BRAKE CYLINDER SEAL 9/16 KADETT/E-CORSA/A 14
550325 90168031 REAR WHEEL BRAKE CYLINDER SEAL 3/4 K/E-CORSA/A-B-ASCONA/C 10
560014 3434432 PAD CLUTCH PEDAL REKORD P-PII '58-'62-REKORD/A-B-C '63-'72 6
565021 90125781 BRAKE MODULATOR ATE DIESEL 35/3 ASCONA/B REKORD/E 1
574807 90135586 GRIP HANDBRAKE LEVER ΑSCONA-MANTA/Β-REKORD/E-ASCONA/C 2
578125 90289643 BUTTON HAND BRAKE (REPL 578627-578130) K/B-C-D-E-R/D/E-ASCONA-MANTA/ALL-VECTRA/A-ASTRA/F 12
607403 90093984 GASKET CYLINDER HEAD 20D ASCONA/B REKORD/E 1
607405 90093986 GASKET CYLINDER HEAD 23YD (REPL 607478) REKORD/E- OMEGA 1
607500 2898962 GASKET CYLINDER HEAD SIDE COVER 1,7L-1,9L REKORD/A/B 6
607660 3456686 GASKET VALVE ROCKER ARM COVER KADETT/B 12
607664 90002406 GASKET COVER CYLINDER HEAD 1.7-1,9-2,0L ASCONA-MANTA/B-REKORD/C-D-E 15
607985 90398045 GASKET CYLINDER HEAD 1,2 ASC-MAN/B.KADETT/C-D 1
607992 90398092 GASKET CYLINDER HEAD 16N,16S,16SH ASCONA/C-KADETT/E 1
608178 0 GASKET TIMING HOUSING BACK PLATE REKORD/P-PII-REKORD/A 5
608181 0 GASKET TIMING HOUSING BACK PLATE REKORD P-PII '58-'62-REKORD/A '63-'65 45
608182 2865970 GASKET TIMING HOUSING BACK PLATE KADETT/A-KADETT/B 9
614815 90156857 SEAL RING CRANKSHAFT 1,6-1,7L-1,9L-2,0L-2,5L REKORD/ALL-ASCONA-MANTA/ALL 1
614817 90156004 SEAL RING CRANKSHAFT 1,6-1,8L ASCONA-MANTA/B-REKORD/E-KADETT/E-ASCONA/C 1
636157 8950942 CAMSHAFT 10-11-12-SR KAD C D Ε OLY 68 2
636320 90088208 GEAR TIMING 1,3 L ΑSCONA/Β-ΜANTA/Β 1
636362 90190996 CHAIN TIMING 20D-23TD-23YDR (REPL 636355) REKORD/D-REKORD/E-ASCONA/B-OMEGA/A 1
636377 8939965 TENSIONER TIMING CHAIN 1,6L-1,7L-1,9L-2,0L-2,5L ASCONA-MANTA/ALL-REKORD/ALL-OMEGA/Α 1
636379 9008086 TENSIONER TIMING CHAIN 1,0L-1,1L-1,2L NEW TYPE (REPL 636375-636378) KADETT/ALL-ASCONA-MANTA/ALL 1
638182 8930326 SEAL RING TIMING SPROCKET HOUSING 17,2X12X5,5MM REKORD/A/B-REKORD/ALL-ASCONA-MANTA/ALL 9
638203 0 TIMING SPROCKET HOUSING 58X44X10MM REKORD/P-PII-REKORD/A 30
638231 8930041 GASKET TIMING SPROCKET HOUSING LEFT REKORD/A/B 7
638232 8930042 GASKET TIMING SPROCKET HOUSING RIGHT REKORD/A/B 10
638234 0 GASKET TIMING HOUSING KADETT/A-KADETT/B 12
638641 8930069 GASKET CAMSHAFT COVER FRONT AND REAR REKORD/A/B/C/D/E-ASCONA-MANTA/B 10
640042 2865507 LIFTER VALVE 1,0L-1,1L-1,2L KADETT/B-KADETT/C-ASCONA-MANTA/B-CORSA/A 16
640380 2898618 CHECK NUT ADJUSTING SCREW 1,6L-1,7L-1,9L-20N/S/E GT-REKORD/ALL-ASCONA-MANTA/ALL-KADETT/ALL 20
640508 2865508 PUSH ROD VALVE 1,0L-1,1L-1,2L KADETT/B-KADETT/C-ASCONA-MANTA/B-CORSA/A 7
640851 2865383 CHECK NUT ADJUSTING SCREW 1,0-1,2L ASCONA-MANTA/B-KADETT/C-KADETT/D 91
642452 8930124 SEAL VALVE STEM 1,6L-1,7L-1,9L-2,0L-2,2L REKORD/A/B/C/D/E-ASCONA-MANTA 16
646023 90009728 PUMP ASSY OIL 1,6 L-1,8L (REPL 646022-646026) REKORD/E-ASCONA-MANTA/B-ASCONA/C-KADETT/E 1
646126 90187327 PUMP ASSY OIL 1,3S ASCONA/B-C-MANTA/B-KADETT/D-E 1
646275 2866216 GASKET OIL PUMP KADETT/A-KADETT/B 9
646347 9292339 GEAR PUMP OIL DRIVING 80,5 STD 1,7-1,9-2,0N/S/E REKORD/D-E-ASCONA/MANTA/B-KADETT/C 1
646529 90091888 GEAR PUMP OIL 1,2-1,3 OHC ΚADETT/D-Ε-ASCONA-MANTA/B-ASCONA/C 1
646560 8930038 GEAR PUMP OIL DRIVEN STD 1,7-1,9-2,0N/S/E GT- REKORD/E-ΑSCONA-MANTA/Β-KADETT/C 1
648401 8930183 GASKET OIL SUCTION TUBE ON CYLINDER BLOCK 1,5L REKORD/A/B 7
648650 0 GASKET OIL SUCTION TUBE ON CYLINDER BLOCK (REPL 648533) REKORD '53-'57 5
650405 8932476 OIL FILTER BASE ASCONA-MANTA/B-KADETT/C 1
650451 9193184 GASKET OIL FILTER BASE ON CYLINDER BLOCK KADETT/A 2
650453 2866848 GASKET OIL FILTER BASE ON CYLINDER BLOCK KADETT/A-KADETT/B 9
656108 90156218 HOSE VENTILATION 1,2L ASCONA-MANTA/B-KADETT/C 1
656825 0 GASKET CYLINDER BLOCK VENTILATOR KADETT/A-KADETT/B 12
658053 9275384 ROD OIL LEVEL INDICATOR 17N 19N 20 22E REKORD/C-D-REKORD/E 1
658060 9275400 ROD OIL LEVEL INDICATOR 16S-1,9L-2,0L REKORD/E-ASCONA-MANTA/A-ASCONA-MANTA/B 4
658087 90144361 ROD OIL LEVEL INDICATOR 1.3 ASC/B ASCONA/B-MANTA/B-ΚADETT/D '75-'88 1
658093 90194095 ROD OIL LEVEL INDICATOR 1,2 L ASCONA-MANTA/B-KADETT/C/D/E 2
658125 2521995 GASKET OIL LEVEL INDICATOR ROD 1,5L-1,7L REKORD/P-PII-REKORD/A 55
658126 2865982 ASKET OIL LEVEL INDICATOR ROD KADETT/A-KADETT/B 13
664099 90170207 DISC ASSY 203DΙΑ (REPL 664121-664128)16-17-19-20 RETURN 9506004 REKORD/A-B-C-D-E-ASCONA/B-MANTA/ALL 2
664182 90348385 DISC ASSY CLUTCH 1,3,L ASCONA-MANTA/B 1
666010 90443334 COVER AND PRESSURE PLATE ASSY CALIBRA C20XE 228mm CALIBRA 1
666055 90018919 COVER AND PRESSURE PLATE ASSY 8,5 INCH 20Ε 216DIA ASCONA/B-MANTA/B-REKORD/E '75-'88 1
668169 2865131 FORK CLUTCH RELEASE 1,2L ΚADETT/B-C-ASCONA-MANTA/A-ASCONA-MANTA/B '69-'88 1
668257 8931631 BOOT CLUTCH RELEASE FORK A/B M/B 16 19 20 R/E 18 ΟΛΑ 4
668642 90111364 BEARING CLUTCH RELEASE 16 17 18 19 20 N/S 20D 20Ε REKORD/E-ASCONA-MANTA/B 2
668645 90112260 BEARING CLUTCH RELEASE F16-F18 16-18-16D KADETT/E-ASCONA/C 2
669033 8940620 CABLE CLUTCH OPERATING ΚADETT/Α-B 2
669082 90095041 CABLE CLUTCH OPERATING DIESEL ASCONA/B 1
669140 90216224 CABLE CLUTCH OPERATING 23TD ENG NO.-0133689>>>> 22D 23D 22E REKORD/E SENATOR/A 1
682515 9290084 BLOCK, DAMPER, REAR MOUNTING 18 20 5 SREED/AUTO (REPL 96221089) ASCONA-MANTA/B 1
682553 90222824 BLOCK, DAMPER, REAR MOUNTING 18 20 24 26 28 30 OMEGA/A-SENATOR B 1
684172 90090958 DAMPER BLOCK FRONT R ASC MAN B 1
684178 90121089 DAMPER BLOCK FRONT RIGHT 16 17 19 20N/S ΑSCONA-MANTA/Β-REKORD/E 1
684182 90135576 DAMPER BLOCK FRONT LEFT & RIGHT 20D REKORD/E '78-'86 1
684251 90095190 BLOCK DAMPER ENGINE FRONT LEFT 13-16-17-19-20N/S/E (REPL 684241) ΑSCONA/Β-MANTA/Β-REKORD/E 1
684255 90168888 BLOCK DAMPER ENGINE FRONT LEFT & RIGHT ΑSCONA/Β-MANTA/Β-REKORD/E 1
684260 0 BLOCK DAMPER ENGINE FRONT LEFT & RIGHT REKORD/Α '63-'65 1
684274 90235055 DAMPER BLOCK FRONT LEFT & RIGHT (AIR HEAVY DUTY) 2,0L-2,3L DIES REKORD/E-OMEGA/A OMEGA/Β 1
684833 0 BLOCK DAMPER ENGINE REAR FROM ENGINE No 15-521849 REKORD/A-REKORD/B 9
702288 6695311 GASKET TRANSMISSION TO CLUTCH HOUSING 4 GEARS TRANS. ASCONA-MANTA/B-REKORD/A-B-C-D-E '63-'86 4
711354 8683084 PLATE, CLUTCH (1.9MM/FLAT) (REPL 711369) KADETT/E-ASCONA/C 3
711367 90093761 PLATE, CLUTCH DISC, THIRD SPEED CLUTCH AUTO TRANS OPEL 3
711422 5258955 PLATE, CLUTCH DISC, DRIVEN, THIRD SPEED CLUTCH (LESS FACING) OMEGA/A-B FRONTERA/B 3
711423 5258956 PLATE, CLUTCH DISC, DRIVEN, SECOND SPEED CLUTCH OMEGA/A-B SENATOR/B 3
711868 8631027 PLATE, PRESSURE, FORWARD AND DIRECT CLUTCH KADETT/E-ASCONA/C 1
711872 8637884 PLATE PRESSURE NLS REPL 711956-711957-711958 AUTO 1.3-1.6-1.8-16D KADETT/D 1
711873 8637883 PLATE PRESSURE NLS REPL 711956-711957-711958 AUTO 1.3-1.6-1.8-16D KADETT/D 1
711874 8643112 PLATE PRESSURE DIRECT CLUTCH AUTO 1.3-1.6-1.8-16D KADETT/D 1
714303 2893341 SEAL RING MAIN DRIVE GEAR 28x49,85/61,5x16 16 17 19 20 ASCONA-MANTA/B-REKORD/E 1
714409 90342145 SEAL, OIL, MAINDRIVE PINION, 23 X 35 X 8 (REPL 714407) F16-F20 Κ/Ε-A/F-A/C-V/A-CAL 1
718900 90077932 SYNCHRONIZER CONE 1 - 2 SPEED (REPL 718948-718937) REKORD/ALL-KADETT/A-B-C-ΑSCONA-MANTA/ALL-ALL FWD 2
718975 90167959 CONE SYNCHRONIZER 1-3-4-5-REVERSE ASCONA-MANTA/B-REKORD/E 1
722043 8977354 GEAR SPEEDOMETER 10-12 KADETT/B-KADETT/C-ASCONA-MANTA/B 1
724388 90065405 GUIDE GEAR SPEEDOMETER KADETT/D-ASCONA/C 2
724500 90090142 OIL SEAL SPEEDOMETER DRIVE HOUSING 33X50X10-12 BLITZ '50-'51-ASCONA-MANTA/ALL-REKORD/ALL 2
724513 KACO OIL SEAL 50-33-10 REKORD '54-'77 1
724524 90006678 OIL SEAL 5 SPEED-OVERDRIVE 38,1x52x20 (REPL 724521) KADETT/C-ASCONA-MANTA/B-REKORD/E 2
724535 3442081 GASKET TRANSMISSION REAR END 16 17 19 20N/S ASCONA-MANTA/B-REKORD/A-B-C-D-E '63-'86 2
724564 90425651 SPEEDOMETER DRIVEN GEAR SEAL RING O/A-K/E-C/A-B-A/C-V/A-CAL 4
725485 8631091 PLATE, PRESSURE, REVERSE SPEED AUTO TRANS KADETT/E-ASCONA/C 1
725657 8631079 PLATE, CLUTCH, REVERSE SPEED AUTO TRANS KADETT/D 5
725658 8637574 PLATE, CLUTCH, CORRUGATED, REVERSE SPEED AUTO TRANS KADETT/E-ASCONA/C 3
725660 8652027 PLATE, CLUTCH, STEEL, REVERSE SPEED AUTO TRANS (REPL 725670) KADETT/E-ASCONA/C 3
725663 96013665 PLATE, CLUTCH, DRIVING AUTO TRANS 16-19-20 ASCONA MANTA REKORD 3
730282 90187004 OIL SEAL 30Χ42Χ7 5SPEED GETRAG KADETT/C-ASCONA-MANTA/B-REKORD/E 1
730876 90344501 GASKET COVER TRANSMISSION CASE 17 19 20 ASCONA-MANTA/B-REKORD/E 2
732234 90094267 OIL SEAL TRANSMISSION 5 SPEED 15X21X5/7 GETRAG C18NE 20S/E 23D/TD REKORD/E-ASCONA-MANTA/B 1
735530 90142018 CABLE, ASSY., THROTTLE VALVE AUTOM TRANSMISSION KADETT/E-ASCONA/C 1
738155 90335380 LEVER ASSY GEARSHIFT 5 SPEED K/D K/E A/C C/A 1
738620 90168062 CABLE, REVERSE GATE RELEASE F10, F16 5 SPEED KADETT/D-ASCONA/C 3
738622 90209777 CABLE, REVERSE GATE RELEASE F10, F13 4 SPEED KADETT/E ASCONA/C 2
738739 90304341 KNOB GEARSHIFT LEVER 5 SPEED OMEGA 1
738950 9277956 BOOT GEARSHIFT CONTROL KADETT/C '74-'79 2
738954 90086178 BOOT GEARSHIFT CONTROL INNER 5 SPEED SHORT REKORD/E '78-'86 1
738961 90168415 BOOT GEARSHIFT CONTROL INNER SHORT SHIFT ASCONA-MANTA/B-REKORD/E 1
738965 90223575 BOOT, GEARSHIFT LEVER 18-20 GSI …….K KADETT/D E 1
747209 96013804 GASKET AUTO TRANSMISSION 16-17-19-20 ASCONA MANTA REKORD 1
747451 5258130 OIL FILTER AUTOMATIC TRANSMISSION KADETT/C-REKORD/E 1
758261 90157088 GASKET, COVER TO BALL CUP, GEARSHIFT LEVER, UPPER CORSA/A 5
761537 90077307 BOOT TRANSMISSION REKORD/E 1
OPEL PARTS GREECE
Discussion Starter #14
806530 8981845 fuel tank hose seal kadett/c 2
808316 90010257 fuel tank cap with keys c/b s/b a/f h/b s/b van v/a 17td 1
808346 90444726 fuel tank cap with no keys manta/a 1
815001 90442402 fuel pump electric( repl 815005-815107-815004) Ω/Α ΟΛΑ f8 Ω/Β Χ20se x25xe 30xe 1
816031 25066082 fuel pump 16 17 19 20 (repl 816036) Α/Α Μ/Α Α/Β Μ/Β r/e 1
816049 5506960 fuel pump 1,3 (25066080) (repl 816050) Α/Β Μ/Β {a/c k/e c/a v/a !!f8} k/d 1
816061 5506974 fuel pump 10-12 ohv k/d k/e c/a 2
816069 90295725 fuel pump 16s 16sh (repl 816062 816074) k/e c/a k/e ast/a 2
817556 17069158 gasket multec all 1
817557 17082049 seal, ring, idle filler reg motor multec inj c12nz,c13n,c14nz,c16nz a/c-v/a-c/a-b frontera 1
817745 90136269 bumper, fuel pump intercooler support to fuel pump mounting bracket cal-c/a-front-k/e-o/a-b 1
818125 0 gasket fuel pump valve plate 1,7l rekord/p-pii-rekord/a 49
818542 9292585 fuel filter 19e-20e ascona-manta/b 1
818545 90019987 fuel flow valve ascona-manta/b 1
818605 2865972 gasket fuel pump flange center kadett/a-kadett/b 10
818606 0 gasket fuel pump flange outer kadett/a 24
818610 0 gasket fuel pump flange outer rekord '53-'57 2
818618 0 gasket fuel pump flange center 1,5l rekord/a/b 2
818629 90323953 gasket fuel pump 1,2 l kadett/c-kadett/e 1
825367 96002218 body, assy., throttle valve 13s (varajet automatic choke type) ascona/c 1
825421 90107400 body, throttle valve (for 90107517 825555) 10s,12n,12nc (weber type) corsa/a 1
826288 90281020 switch throtle valve 18e 18se c18ne ascona/c-kadett/e-omega/a 1
826916 90108282 damper, shut-off (varajet type) 13s 16s 16sh kadett/e-ascona/c 1
827570 90107288 ΚΙΤ ΒΑΛΒΙΔΑΣ ΕΜΠΛΟΥΤΙΣΜΟΥ ΚΑΥΣΙΜΟΥ kadett/e 4
828364 90107204 jet, main (for 9276962 8 25 208) (weber type) 10s corsa/a 1
828370 90107282 jet, main (first step) (pierburg type) 13s 18sv c/a-k/e-a/c-omega/a 2
828612 90107299 jet, idle 13s,13sb 18sv (pierburg type) c/a-k/e-a/c-omega/a 2
828639 3441705 air regulator 1,2l kadett/c-ascona-manta/b 1
828856 90107219 jet, air correction 10s,12n,12nc,e12gv (weber type) corsa/a-kadett/e 1
830745 90107070 float (pierburg-solex type) 10 12 13 kadett/d-e-ascona/c 1
830802 90107206 valve, float needle (for 825208) 10s,12n,12nc,e12gv(weber type) corsa/a-kadett/e 1
830832 3441456 gasket carburettor 12 13n 16n 19n kadett/a-kadett/b-kadett/c-ascona-manta/b 20
830845 96009302 gasket carburator cover variajet 13s kadett/d 1
831701 90107362 box, vacuum 12sohv,12scohv (weber type) corsa/a-kadett/e 1
831735 9276824 box, assy., vacuum 13s (pierburg type) ascona/c-kadett/e 1
831742 90107230 box, assy., vacuum, with pull rod 12 13 16 (pierburg type) corsa/a ascona/c-kadett/e 1
831960 90107498 box, vacuum, with pull rod (repl 831952) 13s,13sb (pierburg type) corsa/a ascona/c-kadett/e 1
832496 90444297 gasket carburator 10 12 13n ascona-manta/b-kadett/d 3
832524 8932694 gasket carburator to induction manifold kadett/a-kadett/b-kadett/c-ascona-manta/b 9
834976 9281374 dumper bushing air cleaner front Αscona/Β-manta/Β-vectra-calibra/a 4
840093 3457435 cable, choke control Κadett/c ascona-manta/b 3
840132 90122378 cable, choke control, lhd 13n ascona/c 1
840140 90231314 cable, choke control, lhd 13s, 16n, 16s, 16sh ascona/c 1
840380 3457429 retaining spring carb.control cable (840296) kadett/c-ascona-manta/b 5
848737 90076379 cable assy accelerator 17 19 20 rekord/d-e 1
848747 90088649 cable assy accelerator 20d (repl 848685) 9009622583 rekord/e ascona/b 1
848945 90190806 cable assy accelerator 18s automatic trans. Rekord/e 1
848948 90194259 cable assy accelerator 20e rekord/a ascona-manta/b 1
848952 90194263 cable assy accelerator 20e ball ascona/b-manta/b '75-'88 1
848975 90264036 cable assy accelerator 13 16s 20n/s 19s ascona-manta/a-ascona-manta/b '69-'88 2
848987 90231928 cable assy accelerator (ident us) 18seh, 20se, c20ne x20se omega/a-b 1
848988 90280131 cable assy accelerator (ident ut) 23dtr, 23yd, 23ydt omega/a 2
850624 8960664 gasket induction manifold 16 19 n/s ascona-manta/b-rekord/e 3
850688 0 gasket intake -exhaust manifold to cyl. Head 1,5l olympia '53-'57 5
850693 0 gasket exhaust manifold rekord p-pii '58-'62-r/a '63-'65 2
850695 0 gasket intake manifold to cylinder head kadett/a '63-'65 25
850696 2865971 gasket exhaust manifold to cylinder head kadett/a-kadett/b 16
850700 8930216 gasket exhaust manifold to cylinder head 1,5l rekord/a/b 2
854835 8932885 gasket exhaust pipe flange 1,5l-1,7l rekord/a/b-rekord/c-d-ascona-manta/b 2
902530 11068251 needle bearing steering rack rod housing lower Αscona-manta/Β 1
904153 90023940 bearing shaft steering column ascona/b-manta/b '75-'88 2
905204 3455209 coupling steering gear to column ascona/b-manta/b '75-'88 1
912200 90334860 bearing steering shaft upper kadett/c-ascona-m/b-r/e Α/c c/a c/b k/e a/f cal/a 1
914460 8949675 ignition lock housing (contacts 914828)(105-8677) rekord/c 1
914478 9288641 case steering safety and ignition (rep 914481) kadett/c-ascona-manta/b 1
914688 0 steering lock cylinder (repl 914677-914672) rekord/b-c 1
914810 9289551 contact part ignition lock diesel ascona/b '75-'81 1
914840 3464051 contact part ignition lock rekord/d 1
1006144 90192828 hub cover 5 bolts monza-senator-rekord/e 4
1008103 1008103 hex nut disc wheel chrome kadett/a-b-c-ascona/a-b-manta/a-b-record/all 16
1101100 9288215 front wing left manta/b 3
1101556 90219578 nameplate gsi kadett/e corsa/a 7
1101577 90179825 moulding gsi front wing legt k/e 2d gsi cabrio 1
1101585 90257113 moulding, protection, lh, front wing kadett/e 1
1101611 2886001 chrome moulding front wing left kadett/b 1
1101630 9286517 moulding protection front left wing left side manta/b 13
1101632 9286519 moulding protection front left wing right side manta/b 1
1101645 9288807 moulding protection front wing left 1st (rep 1101631) ascona/b '75-'81 2
1101647 9288809 moulding protection front wing left 2nd ascona/b 2
1101756 90098028 nameplate rallye kadett/c 1
1102110 90087769 front wing right kadett/d 1
1102577 90179826 moulding gsi front wing right k/e 2d gsi cabrio 1
1102585 90257114 moulding, protection, rh, front wing kadett/e 1
1102602 91073184 moulding, protection opel 4
1102611 2886002 chrome moulding front wing right kadett/b 1
1102632 9286520 moulding protection front right wing right side manta/b 1
1104811 9288022 letter "gt/e" (rep 1324064) manta/b 1
1110088 9289179 front wheelhouse left manta/b 1
1110089 9289177 front wheelhouse left ascona/b 1
1110193 9289180 front wheelhouse right manta/b 2
1160368 90191355 ΑΕΡΑΓΩΓΟΣ ΚΑΠΩ ΑΝΩ l gsi (+ 1160630) kadett/e 1
1160369 90191356 ΑΕΡΑΓΩΓΟΣ ΚΑΠΩ ΑΝΩ r gsi (+ 1160631) kadett/e 1
1170428 90191234 opel emblem chrome kadett/e 1
1178185 3465762 hook bonnet lock (rep 1178188) ascona-manta/b rekord/e 1
1178188 8971976 hook bonnet lock (rep 1178185) ascona-manta/b rekord/e 2
1178209 8971981 spring thrust bonnet kadett/c 8
1190365 90139015 spacer, number plate mounting ascona-manta/b 6
OPEL PARTS GREECE
Discussion Starter #15
1203178 90094038 starter gear bosch kadett/b 1
1208241 90056698 electronic ignition module 1227022008-001 18s/e-20e ascona-manta/b-c-rekord/e-kadett/d-e 1
1211148 90113420 vacuum control for distributor 13 bosch ascona/c 3
1211188 90349444 va control14nv bosch kadett/e 1
1211700 90128169 belt distributor 18n/s c18nv rekord/e 1
1212652 2865977 gasket distributor (repl 1212254) rekord/a-b-c-d-ascona-manta/b-kadett/c 6
1212833 3479004 breaker plate for distributor delco rekord/c-rekord/e-kadett/d-kadett/e 1
1216305 90187443 headlamp assy right '84>>>>>>>>> rekord/e '83>>>> 1
1216308 90187446 headlamp assy left with distance lamp '83>>>>>>>>> rekord/e '83>>>> 1
1216309 90187447 headlamp assy right with distance lamp '83>>>>>>>>> rekord/e '83>>>> 1
1217092 8983230 reflector for headlamp rect lights l&r (1305363900) kadett/c 7
1217095 90019007 reflector for headlamp l & r (1305363904) ascona/b 6
1218763 8972316 cover with gasket headlamp back part kadett/c '74-'79 1
1218766 9288991 cover with gasket headlamp back part kadett/c-rekord/e-ascona/b '75-'81 6
1223060 90007601 lamp, assy., rear, lh gsi kadett/e 1
1223065 90007597 lamp, assy., rear, rh kadett/e 2
1223090 90227478 lamp assy rear left from chassis>>c6067586 manta/b '76-'88 1
1223091 90227479 lamp assy rear right from chassis>>c6067586 manta/b '76-'88 1
1223197 3468309 housing rear lamp l saloon rekord/d '73-'77 1
1223226 90167885 lamp assy rear left d……… rekord/e '83-'86 1
1223227 90167886 lamp assy rear right d……… rekord/e '83-'86 1
1223372 3463365 lens rear lamp left 4door swf (repl 1223350) rekord/d '73-'77 20
1223373 3463366 lens rear lamp right 4door swf (repl 1223351) rekord/d '73-'77 23
1223383 3437916 lens rear lamp right (397810) (repl 1223325-1223329-1223381-1223153) ascona/a 2
1223406 8972353 lens rear lamp left 396677/swf saloon kadett/c 2
1223406 8972353 lens rear lamp left 396677/swf saloon kadett/c 1
1223409 8972355 lens rear lamp left kw kadett/c 1
1223416 8972354 lens rear lamp right kadett/c 1
1223700 3437917 seal rear lamp left 397871/swf ascona/a '69-'74 1
1223702 3437929 seal rear lamp left & right ascona/a '69-'74 rekord/d '73-'77 1
1223703 3437918 seal rear lamp right 397872/swf ascona/a '69-'74 1
1223719 9286585 seal rear lamp left 96d117893005 manta/b '76-'88 1
1223720 9286586 seal rear lamp right 96d117894005 manta/b '76-'88 1
1223721 9285851 seal rear lamp left & right ascona/b '75-'81 2
1226015 90102317 lamp front turn signal left 2ba003702031 82>>>>>>> manta/b '76-'88 1
1226016 90102318 lamp front turn signal right 2ba003702041 82>>>>>>> manta/b '76-'88 1
1226030 90187471 lamp assy front turn signal left '84>>>>>> rekord/e '83>>> 1
1226032 90187373 lamp, assy., side repeater, clear lens, left d……..(22-29 chassis) rekord/e ii monza senator/a 1
1226033 90187474 lamp, assy., side repeater, clear lens, right d……..(22-29 chassis) rekord/e ii monza senator/a 1
1226039 90008396 lamp, assy., front turn signal, rh (clear lens) kadett/e 1
1226041 90008398 lamp, assy., front turn signal, rh (amber lens) kadett/e 1
1226047 90272356 lamp assy front turn signal r white iii ascona/c 1
1226311 90017071 housing front turn signal lamp right rect lights kadett/c 1
1226312 90167803 housing front turn signal lamp l&r >>>'82 (+1226695) manta/b gte 4
1226350 0 lens yellow left Κadett/Α 3
1226351 0 lens yellow right Κadett/Α 3
1226355 0 lens clear right Κadett/Α 1
1226405 3439195 lens front directional signal lamp left (300643) ascona/a 1
1226405 3439195 lens front dir.signal lamp l & r (set 1612262) ascona/a '69-'74 1
1226407 3439196 lens front directional signal lamp right 397820/hella ascona/a '69-'74 1
1226407 3439196 lens front directional signal lamp right (300642) ascona/a 1
1226695 90167805 lens front direction signal lamp l & r (+1226312) manta/b gte 4
1227253 8968447 rear backup light cpl (repl 1227153) manta/a 5
1227433 3439391 rear lens backup light 397527/swf manta/a 3
1234565 90109515 housing with retaining plate Κadett/d 1
1234568 90133000 panel, switches and heater controls surround, instr panel, centre, lhd ascona/c 1
1234606 90109509 housing instraments Κadett/d 1
1238144 3466376 cover fuse block aperture rekord/d '73-'77 1
1238622 3468419 relay windscreen wipers kadett/c-ascona-manta/b-rekord/d 1
1239251 8969775 switch assy reverse lamp gt-ascona-manta-rekord/e 1
1239259 90094637 switch assy reverse lamp (getrag transmission) rekord/e-ascona-manta/b-kadett/c 1
1239280 9283318 switch assy heatable back window 500533/swf ascona/b-manta/b 1
1239285 90069109 switch heater fan kadett/d 1
1239286 90069110 switch heater fan kadett/d 1
1239300 90340744 switch, heater fan and heated back window kadett/e 1
1239308 90361926 switch, heater fan and heated back window, black (3 position) 91' m…….. Corsa/a '91 1
1240024 90213037 switch, contact, interior lamp (repl 1240214) kadett/d ascona/c corsa/a 1
1240079 90069092 switch, assy., lighting, headlamp/interior (repl 1240079) kadett-c-d ascona-c 1
1240102 90172247 switch, assy lights rekord/e 1
1240113 90181186 instrument panel illumination lamp switch kadett/e 1
1240132 90346276 switch, headlamp levelling (ident dg) k/e-v/a- cal-a/f corsa/b 1
1240201 90046276 switch, contact, back heated upper hatch 33, 34, 43, 44 kadett/d-e 2
1240212 90087638 contacts rear door for heatable window (repl 1240201) kadett/d 1
1240584 3458283 switch,brake light rekord/d-kadett/c-ascona-manta/b 3
1240906 3466923 sealing switch contact interior lamp kadett/c-ascona/b-manta/b 6
1240908 90102854 sealing switch contact interior lamp kadett/c-ascona/b-manta/b 8
1241090 90124931 switch, assy., windscreen wash/wipe ……….f ascona/c 1
1241091 90124928 switch, assy., windscreen wiper and washer kadett/d 1
1241095 90126717 switch, assy., 12mm thick, w/wiper and washer, lhd (w/interm wipe) f-j corsa/a 2
1241098 90126719 switch, assy., 12mm thick, tail gate wiper and washer f… corsa/a 1
1241099 90126724 switch, assy., 20mm thick, tail gate wiper and washer …..f corsa/a 1
1241104 90196376 switch, assy., windscreen wash/wipe 85- ascona/c 1
1241105 90191942 switch,wind screen wiper front/rear + p ascona/c 1
1241106 90221175 switch, assy., tail gate wiper and washer (w/wiper & washer) .j 3d-5d kadett/e 3
1241115 90213327 switch, assy., windscreen wiper and washer saloon omega/a senator b 2
1241117 90320299 switch, assy., 12mm thick, w/wiper and washer, lhd (not inter wipe) j. Corsa/a 2
1241118 90320300 switch, assy., 12mm thick, w/wiper and washer, lhd (with inter wipe) j. Corsa/a 1
1241128 90243252 switch, assy., w/wiper and washer (and tail gate wiper) 3d 5d+van j- kadett/e 1
1241129 90243253 switch, assy., w/wiper and washer j- 88- kadett/e 1
1241141 91144147 switch, assy., power window 2 door ud2 frontera 1
1241226 90069121 switch, assy., turn signal/dim/dip kadett/d ascona/c 1
1241239 90126712 switch direction signal lamp (repl 1241226 corsa/a 1
1241246 90221174 switch, assy., turn signal lamp/headlamp full and dipped beam ascona/c kadett/e 1
1241434 90019824 contacts switch turn signal opel 1
1241478 8970298 switch direction signal lamp swf ascona/a-manta/a 3
1241612 90053214 contact heatable back window kadett/d 2
1241897 90055664 shaft switch turn signal lamp/headlamp d……… rekord/e 1
1242000 8967646 cover horn push kadett/c 1
1242035 13326399 bow signal horn less cushion complete (repl 1242332) rekord/c-commodore/a 2
1242037 90032686 cover horn push till c 6067585 (913121) ascona/b-manta/b kadett/d 1
1242047 90092057 cover, horn push…….f kadett/d ascona/c 1
1242052 90203331 horn button 3 spokes kadett/e 1
1242357 3435638 plate horn contact rekord/c '67-'72 1
1244074 9283315 gauge fuel ascona/b-manta/b '75-'88 1
1244084 90123265 gauge fuel 2,0l diesel ascona/b '75-'81 1
1244086 90059139 gauge fuel rekord/e 1
1244616 90034480 printed circuit kadett/d 1
1244619 90034464 printed circuit ascona/c 1
1244623 90041596 printed circuit kadett/d 1
1244630 90119074 printed circuit corsa/ a 1
1244710 90059145 voltage stabilizer rekord/e 1
1248009 90020322 oil pressure gauge ascona-manta/b 1
1252506 8954566 switch, oil pressure kadett/b-c-ascona-manta/b-rekord/all 3
1254140 90148245 fuel tank sending unit diesel (6mm-8mm) rekord/e 2
1254140 90148245 fuel tank sending unit diesel rekord/e '78-'86 1
1254143 90078797 fuel tank sending unit 3d hatch (1254084-1254106) 8mm (12-16-18-20) manta/b 8
1254146 90148244 fuel tank sending unit saloon rekord/e 1
1254147 90148228 fuel tank sending unit 3d hatch 53-55 6mm (1,3l) manta/b 1
1254150 90148250 fuel tank sending unit 20e-22e rekord/e 3
1254151 90148240 fuel tank sending unit 20Ε-22Ε rekord/e 4
1254152 90158252 fuel tank send unit gte 19e-20e hatch manta/b cc 1
1254192 90272252 gauge, assy., fuel (screw fitting) 18seh, 20se,ne, c24ne, 30ne,le …..k omega/a 1
1254194 90272254 gauge, assy., fuel 23dtr, 23yd, 23ydt …..k omega/a 1
1254214 90349438 gauge, assy., fuel 18seh 20se fr ch k omega/a 1
1254225 90360962 gauge, fuel (ident uf) 13-16-18-20 j……. 4-5d kadett/e 1
1254241 90360965 gauge, fuel (ident uf) 13-16-16d-17d j……. Combo /max 38, 48 kadett/e 1
1254246 90443380 gauge, fuel 14nv, 16sv, 18sv, e18nvr vectra/a 1
1254247 90443381 gauge, fuel 17d, 17dr, 17td vectra/a 1
1254278 2598548 gasket fuel tank unit gauge rekord/a-record/b-kadett/a-kadett/b 1
1254279 2893260 gasket fuel tank unit gauge kadett/c-ascona-manta/b 2
1268012 90062170 cable speedometer 18n/s c18nv 4-speed rekord/e 1
1268015 90062173 cable speedometer opel 1
1268030 90119448 cable speedometer 10s 12s st/n/nc/nv/gv 13s/nb/sb 14nv e16se corsa/a 4
1268071 8937580 cable speedometer 15 17 19 22 rekord/c 1
1268154 90016713 cable speedometer 1,2l automatic kadett/c 1
1268187 90017850 cable speedometer 17 18 19 20 22 rekord/e 1
1268204 90094408 cable speedometer 13 18 ascona/b-manta/b 1
1268206 90094842 cable speedometer 20d rekord/e 1
1268208 90094852 cable speedometer(repl 1268187) 18 19 20 23d auto rekord/e 1
1270029 22084017 windshield wiper motor gt '68-'73 1
1272546 3438476 wiper arm left & right 102414/swf ascona/a-manta/a '69-'74 1
1272552 8968340 wiper arm kadett/c 1
1273350 22143294 rear wiper arm 103612/swf kw kadett/c '74-'79 1
1274377 3468055 cap wiper arm (907829/swf) ascona-manta/b-kadett/c-rekord/d 1
1310927 2865652 bumper side radiator kadett/c-ascona-manta/b 5
1312022 90052623 front upper panel gte 16 18e kadett/d 1
1312338 90320103 front upper panel rekord/c 1
1320033 0 grille radiator (ornament type) kadett/a 1
1320054 0 grille radiator (rerl.1320069) ascona/a '69-'74 1
1320082 90017583 grille, assy, radiator gse 2.5l commodore/b 1
1320095 93182717 grille radiator gray gt/e (rep 1320098) ascona/b 3
1320113 90141818 grille radiator '78>>>>'83 black rekord/e 1
1320128 90297246 grille, assy., radiator, grey with emblem f….g ascona/c 1
1320149 90290054 grille, radiator, silver ……l ΟΜΕga a 2
1324065 90138553 nameplate "gte" grille radiator kadett/d 2
1324193 3466477 nameplate opel front grille ( for 1320082-2,8l) commodore/b 1
1324195 3466835 nameplate gs/e front grille ( for 1320082-2,8l) commodore/b 1
1324212 90270528 emblem opel front grille gray 65/84 (repl 1324467) Η…. 87…. Ascona/c corsa/a 2
1324219 9288989 emblem opel kadett/c 2
1324259 9287161 moulding airflow guide panel -side l Μanta/Β 1
1324260 9287162 moulding airflow guide panel -side r Μanta/Β 1
1334029 2866233 water pump 1,1l - 1,2l genuine kadett/b-ascona-manta/a-kadett/c 1
1334029 rerpo water pump 1,1l - 1,2l germany kadett/b-ascona-manta/a-kadett/c 2
1334097 90156532 water pump therm.fan 20s/e r/e 22 exc.air kadett/c gte-rekord/d-rekord/e-ascona-manta/all 1
1334729 0 gasket water pump cover 1,7l rekord/p-pii-rekord/a 48
1334731 2866222 gasket water pump on cylinder block kadett/a-kadett/b-kadett/all-ascona-manta/all 13
1334734 90354908 gasket water pump cover 1,5l-1,7l rekord/a-b-c-d 8
1336347 8958173 cover thermostat housing 17n 19n 20n/s 25 r/d 25 29 ascona-manta-rekord/e 1
1336560 8930323 gasket water pump on cylinder block 1,5l rekord/a/b 4
1336754 8953784 hose radiator lower (+ heater)10-12 Κadett/Β 1
1336788 90094463 hose radiator upper 1,2l (lower 1336872) ascona-manta/a-ascona-manta/b '69-'88 1
1336800 90003922 hose radiator midle (8960206) 19e 20Ε (rep 1336238) ascona-manta/b-kadett/c 1
1336869 90020442 hose radiator lower 19e 20e ascona/b-manta/b '75-'88 3
1336902 90144693 connector 't' 3-way 34-34-20 rekord/e 1
1338209 8966214 gasket thermostat housing on cylinder block 1,5l rekord/a/b 8
1340057 8950130 fan blade 16s 19n/s diesel 360dia ascona/b-manta/b '75-'88 1
1340069 8960064 fan blade (thermostat) 16 19 20 20Ε Αscona-manta/Β-rekord/e 1
1340071 8960512 fan blade 1.6l 2.0l ascona-manta/a-b-kadett/c 1
1340073 8966212 fan blade 1.7l 1.9l 2.0l n/s rekord/d-rekord/e 1
1340097 90096161 fan blade 1.3l ascona-manta/b 1
1340099 90128500 fan, 360mm dia 18nv, 18seh, 18sv, e18nvr, s18nv, 20se, c20ne rekord/e-omega/a-frontera/a 1
1340151 8960124 drive assy fan 16 17 19 20 with middle 17 screw kadett/c-ascona-manta/b-rekord/e 1
1340162 90125548 drive assy fan diesel (rep 1340166-1340167) kadett/c-ascona-manta/b-rekord/e 1
OPEL PARTS GREECE
Discussion Starter #16
1400841 90219232 nameplate gsi front grille kadett/e 2
1402600 90116869 front bumper side left kadett/d 2
1402700 90116870 front bumper side right kadett/d 1
1404578 90116875 rear bumper side left kadett/d 1
1404628 90116876 rear bumper side right kadett/d 1
1404702 90198171 rear spoiler lower left gsi kadett/e 4
1406046 90052511 bracket retaining front panel left kadett/d 1
1406120 8975376 bracket retaining front panel right (wide bumpers) kadett/c 1
1406380 90103020 bracket retaining kadett/d 2
1406391 90102075 bracket retaining rear panel l plast.bumper ascona/b '75-'81 3
1406392 90102076 bracket retaining rear panel r plast.bumper ascona/b '75-'81 3
1406397 90053618 bracket retaining rear panel left kadett/d 1
1406398 90053619 bracket retaining rear panel right kadett/d 1
1406620 90053655 plastic nut-spacer bumper support ascona-manta/b-kadett/d-rekord/e 6
1406620 90053655 plastic nut-spacer bumper support ascona-manta/b-kadett/d-rekord/e 9
1409017 9282137 protective stprip front bumper center manta/b 4
1409033 9946914 moulding front bumper (repl 1409034) rekord/e 4
1409036 90058836 moulding front bumper center rekord/e 17
1409052 90062135 moulding front bumper left rekord/e 1
1409550 90110648 cap rear bumper left & right ascona-manta/b 2
1409901 90018028 clamp front metal bumber moulding rekord/e 100
1428179 90018539 mirror assy left ascona-manta/b '77-'81 2
1428182 90017161 mirror outer l ……..d (metal bumbers) record/e 1
1428184 90017581 mirror assy right black genuine kadett/c 2
1437009 90015458 sun visor right (rep 1437008) black/black kadett/c-ascona/manta/b 1
1437018 90015442 sun visor left turnable black/black ascona-manta/b 1
1437052 90094898 sun visor ascona-manta b kadett/d 1
1437131 90153021 sun visor left kadett/d 1
1437264 90172248 sun visor left fr...d10 opel 1
1437486 90311533 sun visor right light gray (no light) vectra/a calibra/a 1
1437704 90238951 visor, sun, less mirror, light grey, lh-lhd …..e ascona/c 1
1438460 90030917 bracket sun visor white kadett/c 1
1450507 8949046 windshield washer reservoir gt-kadett/b-ascona-manta/b-rekord/e 1
1450577 90226562 filter, pump windscreen wash (repl 1450578) corsa/a-b vectra/a-omega 2
1452711 90037411 spray nozzle rear door hatch 31-32-33-34 kadett/d 1
1603115 90094792 ball joint set kadett/d 2
1603148 90009367 stabilizer bar mountings kadett/d-kadett/e 2
1603150 90009365 stabilizer bar mountings kadett/c-ascona-manta/b 4
1604046 90001934 set gears differential kit 16 19 20 rekord/c-kadett/c-ascona-manta/a-b 1
1604076 6675836 rear joint shaft axle drive u 701 10-12 gt-kadett/a-b-c-olympia a 1,1-1,2l 1963-1979-ascona/manta/a-b 2
1604089 90005158 set washer safety kadett/c ascona-manta/b 4
1604157 90005197 ring & gear pinion 35:11 19s nn8949551 ascona-manta/b 0
1604158 90005198 ring & gear pinion 31:9 1.9 -2.0 ah8932741 ascona-manta/b 0
1604189 90005213 set gears differential kit rekord/d-e 2
1604206 9293006 set gears differential kit 1.2l kadett/c-ascona-manta/b 1
1604206 9293006 set planets differential kadett/c-ascona-manta/b 1
1604240 90009331 ring & gear pinion 35:9 (tt-ap 2888704) rekord/d-e 7
1604241 90009326 ring & gear pinion 37:10 (90009326) rekord/d-e 1
1604241 90009326 ring & gear pinion 33:9 rekord/d-e 1
1605014 2894563 set gasket caliper piston 45mm 13.0441-4807.2/ate rekord/c-d-commo 28
1605016 8939311 set gasket caliper piston 13.0441-4404.2/ate 11.0101-4404 kadett/b '66-'73 2
1605216 3469270 brake caliper set 48mm (rep 1605162) 11.0101-4825 ascona-manta/a-b-Κadett/c-rekord/d-e 2
1605222 3476404 seal rings for double equalizer tank delco 3476404/dr kadett/c '74-'79 4
1605241 3469941 kit inner parts main cylinder 17mm rekord/c 1
1605242 3469942 kit inner parts main cylinder 19mm 17 20 diesel rekord/c-rekord/d 1
1605243 3469943 kit inner parts main cylinder 19mm 17 20 diesel rekord/c-rekord/d 2
1605245 3469945 kit inner parts main cylinder 20mm (repl 1605488-1605551) kadett/c-ascona-manta/b 2
1605440 3476460 kit inner parts main cylinder 3476460/delco ascona-manta/b-ascona/c 2
1605464 3487152 set gasket caliper piston 3487152/delco ascona-manta/b-kadett/d-kadett/e 2
1605465 3487154 set gasket caliper piston kadett/d 1
1605484 90094816 set gasket caliper piston 48mm ate ascona/c-kadett/e-vectra/a 2
1605576 90166854 set, sliding sleeves, caliper (repl 1605656) ate floating caliper ascona/c-kadett/e-vectra/a 2
1605589 90187364 kit inner parts main cylinder piston & seals kadett/d-kadett/e-ascona/c 1
1605603 90006870 kit inner parts main cylinder piston & seals de18e 18se c18ne ascona/c 1
1605693 90295004 set, gaskets, caliper (for 90295000 5 42 255, 90295001 5 42 256) ate omega/a senator/b 2
1605747 90297768 set, sliding sleeves, caliper (repl 1605905)11.0101-5406 v/a-c/a-b-k/e-a/f-o/a 1
1605950 3495611 kit, inner parts, main cylinder, dr (repl 1605702) ast/f-asc/c-vect-k/e-cor/b 1
1606038 0 engine gaskets set sz kadett/a '63-'65 2
1606060 0 engine gaskets set 10n kadett/a '63-'65 1
1606063 0 engine gasket set kadett/a '63-'65 1
1606228 3443847 oil pan gasket set 10 12 ohv Αscona-manta/b-kadett/c-kadett/d-k/e c/a 15
1606230 8983127 oil pan gasket set 1,6l-1,7l-1,9l-20n/s-20d rekord/all-Αscona-manta/all-kadett/c 1
1606253 93178489 engine gaskets set 1,7l rekord/a-rekord/b-rekord/c '63-'72 1
1606268 90005327 engine gaskets set (repl 1606250) ascona/a-manta/a '69-'74 1
1606294 90005353 set timing gears diesel (with chain 636362 ) 2,0 2,3 d,td ascona/b-rekord/e 1
1606297 97719426 engine gaskets set 16n ascona/a-manta/a '69-'74 1
1606298 97719427 engine gaskets set 16s ascona/a-manta/a '69-'74 1
1606348 90005391 cylinder head gaskets set 16s ascona-manta/b-kadett/c 1
1606462 90016605 set gaskets cylinder head 23yd 23td 23td rekord-omega frontera 1
1606491 90093990 set gaskets cylinder head 20d ascona/b rekord/d-e 1
1606613 90271828 kit, clutch repair gte 18e 18se kadett/e ascona/c 1
1606675 90397805 gasket set, top overhaul 12n/s/sc k/c,asc-man/b-c/a-k/e 1
1606678 90397811 gasket set, bottom overhaul 18n/s ascona/b-manta/b rekord/e 1
1606679 90397812 gasket set, bottom overhaul 13n 13s ascona/c-kadett/e-corsa/a 1
1606720 90398573 gasket set, bottom overhaul 21d 23d rekord/d-e-omega/a 1
1607025 90002016 bearing needles and spacer washers Κadett/Α-b 10
1607133 90140148 set, gaskets autom.trans. Bedford 1
1608004 0 fuel pump repair set pierburg (repl 1608008)(rp-816-04-007) gt-rekord/a-b-c-kap-commo-blitz-olympia/a 16
1608013 0 carb.rep. Set for 816013 (rp-826-064-826-052) (repl 1608035) gt-rekord/a-b-c 6
1608023 0 carburator repair set(repl 1608035) (r826052/064) gt-rekord/a-b-c 5
1608039 8939273 set jets carburetor (repl 1608230) 1,7l-1,9l rekord/c 12
1608044 8939283 carburator repair set (rp-826-073) 2,5l commodore/a-b 7
1608129 5507236 fuel pump repair set for 816025-816026 a/c rekord/a-b-c-d-ascona-manta-kadett/b-c-blitz 2
1612102 opel-repro lamp rear right saloon cpl (1224253 + 1224065) record/c '69 1
1612129 2ba001268021 lens & housing cpl front dir.signal lamp yellow right 2ba001268021 rekord/a-rekord/b '63-'66 6
1612258 0 lamp assy.rear left 300637/swf (repl 1612322) ascona/a '69-'74 2
1612259 0 lamp assy.rear right 300636/swf (repl 1612323) ascona/a 1
1612259 0 lamp assy.rear right 300636/swf (repl 1612323) ascona/a '69-'74 3
1612379 0 lamp assy rear lisence plate 2ka002635011/hella repl 1224126-1224127) kadett/c '74-'79 1
1612386 8983587 lamp assy rear l saloon (300823) (repl 1612284) (1223197+1223350) rekord/d 1
1612386 8983587 lamp assy rear l saloon (300823) (repl 1612284) (1223197+1223350) rekord/d '73-'77 25
1612387 8983588 lamp assy rear r saloon (300822) (repl 1612285) (1223198+1223351) p/h rekord/d '73-'77 12
1612387 8983588 lamp assy rear r saloon (300822) (repl 1612285) (1223198+1223351) metal housing rekord/d '73-'77 8
1612390 8983591 lamp assy rear left commodore (13-19) (1223360+1223197) commodore/b 4
1612391 8983592 lamp assy rear right commodore (13-19) (1223361+1223198) commodore/b 4
1612434 90113411 spark plug wires set k/b k/c a/b c/Α k/d e 10 12 ohv 1
1614057 90114895 set bracket retaining front panel rekord/e senator/a 1
1702761 90167275 cap fuel tank with keys c/a k/d k/e 0808331 1
1704604 90172631 mirror assy left '84>>>> rekord/e 1
1704727 8983378 mirror assy right chrome convex kadett/c-ascona-manta/a 11
1704736 repro mirror assy r sport gte -200-400 (repl 1704737) ascona/a-b-manta/a-b gt/e 200-400 5
1704737 repro mirror assy l sport gte -200-400 (repl 1704737) ascona/a-b-manta/a-b gt/e 200-400 5
1704742 90017524 door mirror left adjustable from inside black kadett/c 1
1706946 90045613 cover seat belt manta/b 2
1719131 90060256 front spoiler lower right rekord/e-comodore 16
1719949 90297165 stripe, styling, tail gate spoiler black hatch gte gsi kadett/e 10
1720865 8947057 switch reverse lamp 1,2l kadett/b-kadett/c-ascona/b-manta/b 9
1728855 8940745 switch interior lamp kadett/c 6
1728860 90087504 switch hand brake ascona-manta/b-corsa/b-omega/Β-astra/g fron/a 2
1742015 90167786 set, installing, clock …..h…….'87 corsa/a 1
1742091 90265582 set, installing, clock j….Μ 88-91 corsa/a 1
1745330 1745330 cover, blanking, assist handle mounting holes opel 5
1745332 90308135 cover, blanking, assist handle mounting holes, light grey vectra/a 2
1745369 90442927 pivot handle assist roof kadett/c-ascona-manta/b 31
1747040 8972943 lamp assy roof-engine-luggage compartment kadett/c-kadett/d-ascona-manta/b 1
1747509 90019219 set wires installing engine compartment lamp ascona/b-manta/b 10
1747623 90008826 set, installing, luggage compartment lamp hatch, saloon 33, 34, 39, 49 kadett/e 1
1747625 90010361 set, installing, luggage compartment lamp hatch 98, 99 corsa/a 1
1747803 90046278 switch interior lamp kw rekord/e 1
1814405 90069302 air hose outer l kadett/d 1
1814406 90069301 air hose outer r kadett/d 1
1814992 90512606 grille, defroster, instrument panel, rh-lhd astra/f 1
1814993 90512605 grille, defroster, instrument panel, lh-lhd astra/f 2
1818123 90240344 hose heater corner 21mm outlet, conn to engine 13s c14nz ascona/c kadett/e 1
1818218 8972529 heater hose (+1818250+1818299) kadett/c 1
1818238 9287503 heater hose 1,2l (+1818316) ascona/b-manta/b '75-'88 1
1818239 9283524 heater hose 16 19n/s 20n/s ascona-manta/b 1
1818335 90191666 hose heater corner 22mm 13s kadett/e ascona/c 1
1818459 94420249 connector, 3-way, 17-17-9 outlet, heater, radiator to cold start corsa/a kadett/e vectra/a 1
1818551 6668814 heater hose kadett/a-ascona-manta/b 2
1818559 90184059 connector 't' 3-way 18s 20n/s for sensor rekord/e 1
1820300 2870308 thermostat switch heater control opel 1
1822014 8947905 control lever temperature housing from c 1234068 Κadett/Β 1
1822554 90060005 control housing heater contacts rekord/e 1
1942040 93165210 oil, engine, sae 5w-30, 2 litres (gm) (1942207) nls 1942001 all 18
1942050 93165220 oil, engine, sae 15w-40, 5 litre (gm) (1942037 1942199) all 6
2000296 11072883 screw hex front stabilizer shaft m8Χ166 (repl 2000277) kadett/c-ascona/b-manta/b '75-'88 7
2000354 11067452 screw hex cylinder head cover m9x100 kadett/b-kadett/c-ascona-manta/b 4
2060670 11053153 plug york 40mm 10 11 12-ohv kadett/c-kadett/d 6
2060671 11056821 plug york 46mm 2,1l diesel (repl 607739) rekord/d-rekord/e-omega/a 6
2060673 11084312 plug york 28mm ascona/c asttra/g 5
2086116 11052752 sleeve tension door to body Κadett/Β-kadett/c 9
2086117 11063012 sleeve tension door to body kadett/c-ascona-manta/b 34
2091016 0 seal ring oil drain screw 1,5l rekord/a/b 6
2091018 11060089 seal ring oil drain screw 21,9x16,2x2mm rekord/a/b 3
2091029 11044909 seal ring oil drain screw 1,7l 32,3x37,9x2,5mm (n 42650) rekord/p-pii-rekord/a 44
2091046 11023582 seal ring oil drain screw 20x14x2,5mm kadett/a-kadett/b-all 11
2208040 90436507 interior upper panel left kadett/b 1
2208200 90436226 interior upper panel right kadett/b 1
2208807 90099084 clip rivet rekord/e 3
2222168 90262529 cover, sill panel and carpet, front, lh, anthracite (repl 2222379) ascona/c 4
2222171 90262530 cover, sill panel and carpet, front, rh, anthracite (repl 2222380) ascona/c 4
2222174 90262545 cover, sill panel and carpet, rear, lh, anthracite (repl 2222381) ascona/c 8
2222177 90262546 cover, sill panel and carpet, rear, rh, anthracite (repl 2222381) ascona/c 7
2222302 90110233 inner cover sill panel front left 4d-5d kadett/d 2
2222303 90110234 inner cover sill panel front right 4d-5d kadett/d 20
2222304 90110235 inner cover sill panel rear left 4d-5d kadett/d 2
2222322 90152065 cover, sill panel and carpet, front, lh, beige ascona/c 2
2222323 90152066 cover, sill panel and carpet, front, rh, beige ascona/c 1
2222391 90171035 cover, sill panel and carpet, front, lh, dark brown ascona/c 2
2222392 90171036 cover, sill panel and carpet, front, rh, dark brown ascona/c 2
2222393 90171037 cover, sill panel and carpet, rear, lh, dark brown ascona/c 1
2222394 90171038 cover, sill panel and carpet, rear, rh, dark brown ascona/c 1
2222802 8974599 clip cover luggage compartment Αscona/b-manta/Β-kadett/c 19
2222804 90115446 clip cover luggage compartment kadett/d 12
2222840 90296970 clip kadett/e 19
2353228 90237316 trim, assy., roof rail, rear, grey saloon (39,49) kadett/e 2
1101-1102 1101-1102 set chrome mouldings wheelhouse kadett/b 4
1704 circ repro oldtimer mirror l & r circular kadett/rekord 2
1704 oval repro oldtimer mirror l & r oval kadett/rekord 2
1704 rect repro oldtimer mirror l & r rectangular kadett/rekord 2
a90122255 a90122255 set trunk lid lock cylinder ascona-manta/b 1
rp 816-04 rp 816-04 fuel pump repair set (repl 1808008) olympia/a - gt 3
1 - 16 of 16 Posts
