Here is a good one. I drove the Gt into the shop yesterday to start replacing the old rubber with polyurethane. Drove fine, in fact went around the block to make sure everything was working. Dropped the rear end, pulled it out, removed everything, took the forklift and moved it up to the pressure washer.Today I sprayed it down with Marine clean, pressure washed almost all the accumulated grime off, moved it back to the shop to dry. Went back a while ago, pulled the drums off, and for some reason spun the axle by hand. No movement through the torque tube at the universal. Thought that's strange, took the torque tube off, tried again. Still no movement at the pinion nut? Took a universal wrench and turned the pinion nut, it turns freely with slight movement of the axle. Held the axle and did the same thing, no movement at all. I was so hot and disgusted I quit and came back up to the house. I haven't taken the back cover off yet to see what I can see. Anyone have any ideas? I can't figure out what I could have done. Thanks, Jarrell
