Wondering if anyone has any recommendations on brand and weight of oil for my specific situation. I have a '73 GT with what I believe is the original 1.9L with 198,000 miles, pretty much all stock. Not sure if it was ever rebuilt. It smokes when you start it, so the rings are probably worn. Plus it leaks in a number of places...bad gaskets I suppose. I probably add one or two quarts per 1000 miles.
My goal is to get about another 20K - 30K out of this engine with as little expense as possible before rebuilding or replacing the engine. I've ruled out synthetic because of the cost and concerns about using it in such an old engine (I've heard it can actually be harmful). I used Castrol GTX 5W30 when I got it out of storage because I had some left over (I use it in my low mileage Caddy). I will be changing it again in 500-1000 miles because of the fact it's just out of storage, so I thought I'd get opinions first.
