OR you can add another tool to your collection that reduces the effort considerably, a Lisle Wheel Stud Installer. It allows the use of a regular lug nut (not the mag wheel style with a washer) and has bearings that reduces the friction making it an easier install than using the washers that Gene suggested. Granted the washer method works, is cheaper and you may already have these items at your disposal. If you do very many stud installations though it might be worth investing in.There is another, less painful method, at least on the rear axle, you can pull the studs through, by going to the hardware store and getting a heavy (size, not weight) 12 X 1.5mm hex nut and a few 12 mm flat washers. Then purchase the longest, cheapest boxed wrench or a deep inpact socket (preferably 1/2" drive) and a pull handle. Use a bar of ordinary hand soap, and rub the knurled area with the soap, then insert the stud from the back, put on washers from the front then thread nut on, and crank it till the head on the back side is flush.
This is repeated in another thread right now, so I am also adding that info here.OR you can add another tool to your collection that reduces the effort considerably, a Lisle Wheel Stud Installer. It allows the use of a regular lug nut (not the mag wheel style with a washer) and has bearings that reduces the friction making it an easier install than using the washers that Gene suggested. Granted the washer method works, is cheaper and you may already have these items at your disposal. If you do very many stud installations though it might be worth investing in.
Harold
