1 - 7 of 7 Posts
Moderator
does any one know if saturn or ford 4 bolt rims will work on the opel?
I believe Saturn uses 4 x 100 mm, but the offset is front-wheel drive. Ford uses a larger pattern, the exception being the later Ford Escorts made by Mazda (also 4 x 100).
Moderator
well i decided to powder coat my rims. the car is going to be yellow (and it is now) what color should the rims be gray, white, yellow?
Nope. I did a quick Google search (I am continually AMAZED at the power of Google!) and found a Yahoo Pinto site with the answer:
http://autos.groups.yahoo.com/group/pintocarclubofamerica/message/2071
and the answer is:
"Pintos have a 4X4.25" bolt pattern"
which is about 108 mm. And the next question is: what the heck is a Pinto Pangara, and why???
Detritus Maximus
The "Pangra" was a 70's 'styling kit' fiberglass package to make your Pinto look 'cool', or exotic, or something (I actually like the first couple years of Pintos; small back window, thin bumpers, sub-2000 lb. weight, and a 100hp stock (with the right motor).
Grey wheels would look best on a yellow car. What shade of yellow? Primrose, school bus, banana? Dark grey works with the school bus yellows.
Moderator
its called sunshine yellow, its close to canary yellow. and i will be powder coating my rims grey, but what should i do with the center hubcaps?
1 - 7 of 7 Posts
