1 - 13 of 13 Posts
belly pans rot bad, lower fenders behind the front wheels where usually first to go out and they seem to rust alot around the antenna in the fender. seems like the floor pans under the drivers feet like to get rotten along with the bottom of the tail piece.
It's stupid, my Opel is completely rust free, except when you get to the front side panels. Right behind the front wheels, it just starting to bubble near the bottom on one side, and on the other it's got rust pretty bad. Why in this one spot behind the wheels and not others? No clue. But definitely check there. If it doesn't have rust there, it's either a heck of a car or has been restored previously.
Looking for rust?
The spots discribed above are all common areas to have rust. I think it depends on the environment your car has been in for the last 30 years. I was fortunate that my '72 had been wax oiled in the fender wells probably early on. That and the fact that it was a "California car" means the commom rust areas were in great shape. But at some point 10 or 15 years ago it went into storage. My thought is that it was stored in a metal shed because of condensation rust. Anything that is warm during the day and then cools at night will condensate (if there is moisture in the air). This moisture will start surface rust on exposed iron. I have found this light surface rust in the most protected areas of the car.
Storing in a real garage where temperature and humidity are somewhat more controlled seems to help quite a bit (my garden tractor doesn't rust near as bad in a brick garage as it did in the cheap-o metal shed).
Re: Looking for rust?
so i should try and find a car from a warm dry area that was stored in a brick grauge. then i dont have to worry about it. :D
Almost all Opel GTs have rust in the belly pan and battery Bo,x. That happened on the showroom floor.
If it doesn't have rust there then it's been repaired.
Reactions: terrylewisac
MODERATOR'S NOTE:
You have posted this video in (at my current count) NINE (9!) threads. Not cool. And not allowed or tolerated. The rule is clear: one post (or thread) per topic. Otherwise it is just spam.
So, you have a choice. Either delete all but one of these posts, or it will happen in a very indiscrete manner. Current thought is to label you a spammer and "clean" all your posts.
Please advise.
1 - 13 of 13 Posts
