Speaking of S-10 clutches, I was working on a part to compliment that setup. The S-10 clutch, because of the longer diaphragm fingers, requires a different clutch adjustment than that of the stock Opel item. There's more travel required on the clutch arm to fully release the clutch. Generally, instead of a lower clutch arm adjustment of 4.25", I set it to 4.75". However, the only downside to this is that the clutch arm pivot stud will then be at the end of it's adjustment, that is, the lock nut will be right at the end of the threads of the stud. So if you need to adjust for wear later on, there's nothing to adjust to.
The only thing that works is tightening up the clutch cable, but it creates a higher pedal that is much stiffer from bad leverage. So I am thinking of making a longer stud for this application. Probably no more than 10-20 pieces, at least initially. Anyone interested? Price unknown exactly, but should not be much more expensive than a new OEM pivot stud.
