1 - 2 of 2 Posts
Does anyone know of a conventional yoke for the pinion of the rear axle that will replace the barrel spline and allow the axle to be used without the torque tube? Perhaps from an older or newer Opel? Or does anyone have a pinion loose that they can compare with the front end of the rear driveshaft just in case they are the same?
I have a project in mind to use up one of my "extra" axles and the torque tube is neither required nor desired.
1000 Post Club
Stephen you always seem to have something up your sleeves, dont you? Cant wait to see what you have come up with now.
Adam
1 - 2 of 2 Posts
