Yesterday I was adjusting (yet one more time) my drum brakes. I had the side of the wheel on stand, and after adjusting once I started the engine to pump the pedal with the servo-assistance a couple of times, then to make the final adjustment. When I started the engine the wheel that was jacked rotated! I looked under the car, and though the gearbox was in neutral, the propeler shaft was rotating...
Should this happen?
yes thats normal
Even though the engine is not mechanicaly connected to the wheels through the transmission the fluids inside the tranny are providing a viscous connection. Much the way an automatic transmission torque converter works. Perfectly normal as Baz said. HTH
Mike
70 GT
73 GT
72 Manta Rallye
73 Super Beatle
68 RHD Austin Mini
wow good timing, today i started taking a look at my transmissions that i have laying around and i noticed that the output shaft rotates when i turned the input when it was in neutral... it had me scared there for a bit... good to know its ok :)
Ok guys, thanks a lot! I have to admit that this scared me a bit...
