WE HAVE IGNITION!!
The engine has the most unbelievable sounding growl I've ever heard! I'll have to record it somehow. I only let it run for about 30 secs during a few test fires and shut it down for a quick inspection. It was getting late and I need more light for viewing. I can't get over how it sounds. It's not too loud with the exhaust setup I have (single Magnaflow with no resonator). It seems to be able to rev effortlessly. And the growl from the 45's are amazing. I still have the stacks on them but will eventually go to a full filter setup.
Let me rewind to the beginning of the afternoon: Since I was having an issue with my ignition saving relay I went ahead and removed it. After the wires were back to the original setup I tried to turn it over. Nothing. Then smoke. Damn, I totally forgot about the resistor wire to the coil. Disconnected everything and ran a regular wire to the coil (In this case the positive side of the Compufire Ignition) Ok, so it was getting 12v now. Still no starter. I looked up the stock wiring diagram and found the error. I had the pos/neg side of the starter backwards. Dumbass! Sure enough, she turned over. Since that worked I wired the relay back up. She still turned over! Great! Let's move on... She'd crank just fine but I couldn't get any gas. I knew I wasn't, because I could see the glass filter that was positioned just before the fuel pump was still empty. I decided to pull the filter out and see if I could get gas from the tank. Yep, it was bubbling out but no passing thru the filter. I tried starting (I had the 12v lead to the CompuFire module disconnected because I didn't want to damage it from constant 12v) in hopes of drawing fuel through. It wasn't working. Maybe if I primed the carbs a little. I pulled the jet inspection covers off and dropped a little gas in. Tried starting...it burped!! In fact, it sounded as if it was going to fire!! The excitement began to build! At this point I knew all I needed was gas flow to the carbs. I kept cranking and priming the carb until I saw a little fuel shoot out a section of the fuel line. It was loose. My neighbor, Rob also pointed out another loose connection on the line. Tightened everything up and tried again...
She awoke!
It wanted to rev so fast I had to shut it off and adjust the idle. It turned out my throttle cable was tensioned too high. After a few more little adjustments and shutdowns I called it good for the night. It was getting dark and I wanted to see around the motor better. I did find one of the carb mounting screws nearly all the way off. I must have missed that one.
I look forward to tomorrow.....
...but first, a cold shower. Really cold shower....
She awoke!
