Straight from the book
Here ya go straight from the book . I am assuming you have a 1.5 or 1.9 it is pretty much the same for these.
1. Remove air cleaner (above carburetor)
2. Disconnect fuel and vacuum hoses from the carb.
3.Disconnect 2 hoses from water heated automatic choke (if so equipped). Plug holes so as not to lose coolant.
4.disconnect throttle linkage by unsnapping ball socket from ball on end of throttle shaft.(i used screw driver be carefull !
5. On manual choke models disconnect bowden cable from carb.
6. Remove nuts and washers fixing carb to intake (should be four of them)
7. remove the carb and gasket from manifold.
Hope this helped!
