I need to repair my Solex. The kit from OGTS shows hoses that should hook up that mine did not have. Two differences in my setup.
One, instead of the small line from the valve cover to the manifold, both ends were plugged. The valve cover has a small blue rubber or nylon plug in the hole and the manifold has a rubber plug over it. Any harm in leaving it this way? The big line from the valve cover to the air cleaner cover is in place.
Second item is the two lines that are supposed to go from the carb to the charcoal cannister were instead tapped into the vacuum hose from the brake booster. The book says the charcoal cannister is by the battery, but there apprears to be nothing of the sort up there. Should I leave the brake booster line connected to the carb or should I find a charcoal cannister and plumb that in or is there another option?
Both lines to the distributor are in place, but are pretty brittle feeling. Can these simply be replaced by any similar sized line from an auto parts store?
