170175 0 weatherstrip rear windshield kw ascona/a 1
522515 0 brake cable rear 1,6l ascona/a 1
1223383 3437916 lens rear lamp right (397810) (repl 1223325-1223329-1223381-1223153) ascona/a 2
1226405 3439195 lens front directional signal lamp left (300643) ascona/a 2
1226407 3439196 lens front directional signal lamp right (300642) ascona/a 2
1312179 0 panel front end lower ascona/a 3
1612259 0 lamp assy.rear right 300636/swf (repl 1612323) ascona/a 4
522521 0 brake cable rear 1,6n 1,2l ascona/a 1
1223700 3437917 seal rear lamp left 397871/swf ascona/a '69-'74 1
1223703 3437918 seal rear lamp right 397872/swf ascona/a '69-'74 1
1320054 0 grille radiator (rerl.1320069) ascona/a '69-'74 1
1612258 0 lamp assy.rear left 300637/swf (repl 1612322) ascona/a '69-'74 2
1223702 3437929 seal rear lamp left & right ascona/a '69-'74 rekord/d '73-'77 1
914801 8972371 contact part ignition lock (repl 914837) ascona/a manta/a kadett/c rekord/d 17
1713447 90045080 plate base parking lamp ascona/a-b-manta/a-b 14
1713600 8932338 seal plate base parking lamp ascona/a-b-manta/a-b 2
1704736 repro mirror assy r sport gte -200-400 (repl 1704737) ascona/a-b-manta/a-b gt/e 200-400 17
1704737 repro mirror assy l sport gte -200-400 (repl 1704737) ascona/a-b-manta/a-b gt/e 200-400 17
414552 8940587 o' ring rear axle shaft ball bearing 17n 18n/s 19n 20 ascona/a-b-manta/a-b-rekord/e 4
310814 heyd-lemf guide joint upper control arm (repl 310819) (71/52/40/13,5-14,5 m12 parak) ascona/a-manta/a 4
324250 heyd-lemf axial joint tie rod end l&r ascona/a-manta/a 20
1241478 8970298 switch direction signal lamp swf ascona/a-manta/a 3
1272546 3438476 wiper arm left & right 102414/swf ascona/a-manta/a '69-'74 1
1606268 90005327 engine gaskets set (repl 1606250) ascona/a-manta/a '69-'74 1
1606297 97719426 engine gaskets set 16n ascona/a-manta/a '69-'74 1
1606298 97719427 engine gaskets set 16s ascona/a-manta/a '69-'74 1
174722 3438722 clamp moulding ascona/a-manta/a-ascona/b-manta/b 20
