1 - 10 of 10 Posts
Good Morning Norbert
I am a little confused the link you gave is for the clear lenses
Hate to ask this but what are speed nuts anyway
I have never heard of this
Those speed nuts don't work very well. I call that type "sheet metal nuts". They are also called "push nuts" because you don't really screw them on, you push them on. There are round ones that work much better than those rectangular ones. I didn't like how poorly they held the lens in place, so I added Goop glue around the edges. That worked very well. The nuts weren't needed.
The posts in the turn signal cans that you push those nuts onto are about 1/8" in diameter. That is the size to look for.
These are push nuts:
https://www.ebay.com/itm/260pcs-Star-Nut-Metal-Starlock-Push-on-Locking-Washer-Fastener-Assorted-Set-US/352776198740?hash=item5223199a54:g:DdUAAOSwcytdbgAQ
This type is what I call a real speed nut that you can screw on and off:
https://www.ebay.com/itm/10733-Speed-Nuts-5-16-stud-x-1-2-Hex-10-Pieces-Chevy-Ford-Pontiac-Buick-Olds/254447315596?hash=item3b3e3dea8c:g:u98AAOSwF1dURqiC
AH OK I understand now
Sorry to butt in just never heard them called that
Thanks for learning me:yup:
Discussion Starter #5
Thank you Gordon
But I need the same as Gil show up.
Only two cramp at each nut.Must be rectangular!
The round ones are to hard to lose them by repair.
Most the dealers here sell the round ones,I say:no::no:
I think I can get those at my local hardware store.
Your Noble Friend ;-)
How does this look? 10 x 15 mm, the round hole part in the center is 2.7 mm dia, galvanised spring steel (verzinkter Federstahl). The shown screw is a #8 sheet metal screw (outside dia 4mm).
I have a couple hundred in my stash.
Dieter
Detritus Maximus
McMaster-Carr in the US or maybe a good Wurth distributor in the EU.
Dieter
I think your part is correct.Where you buy them? I only need 32 speed nuts.
Norbert
Leftovers from work. We used them on the older (W166) AMG ML/GLE bumpers. I'll be happy to put a handful in a letter to you, PM me your address again.
Dieter
1 - 10 of 10 Posts
