GTAlex1900 said:
I have a question relating to the speedometer in my car. I bought a 1970 GT 1900 only a few days ago. <SNIP> The magnets on both the tach and speedo were weak, it seemed, when I bought the car, because the needles would always bounce when first accelerating from a stop. Now the speedo only occasionally moves, and when it does, it gives an inaccurate speed reading. Does anyone know of a solution that does not involve installing a new speedo?
As noted, you may have to open up the dash ... Good idea to find a Factory Service Manual (usually eBay) for future references.
My 71 GT Speedometer would bounce from 0 mph to approx 35 mph. Installed new cable from
www.opelgtsource.com (lubricated before installation).
NOTE: ONLY ACCOMPLISH ON DESERTED ROAD FOR SAFETY!!
While driving, found out that I could reach behind speedometer where cable is attached. Was able to tweak cable alignment, so that speedo needle bouncing almost went away. Not the safest task, but accomplished on deserted road traveling under 35 mph. You could park GT, tweak cable, drive, and see if bouncing decreases. Repeat process ...
Eventually I will find another speedometer with odometer of 4X,000 miles and will will swap when miles approx. match.
